- Jul 26, 2008
I don't know if anyone else has encountered this same problem, but I wanted to share an interesting thing I just discovered today....
I have these large blades of 5160 that I originally drilled 1/8" holes into the tang. The 1/8" bit drilled really easily through the 1/4" steel, no problems there. Later on I changed my mind and decided I wanted 1/4" holes in the tang for the pins instead of 1/8". This is where the problem started. It seemed that because there was already a smaller hole in the steel, when I went to drill into it with a larger bit, it did not want to bite into metal. The larger 1/4" bit just spun out in the 1/8" hole and made a bunch of noise and causing the bit to go dull in just a few turns. Tried going slow even, but that didn't seem to work either. Ruined two brand new drill bits trying to drill out one hole.
I even tried using a Cobalt bit, but it wrecked that one as well.
For whatever reason, I could not get the 1/4" bit to drill through. I had a similar problem before with some 1095 that I was trying to drill through. I don't really know what causes this problem, but I did find a rather unorthodox solution. I found that instead of an actual drill bit, I put a small carbide cutter in the drill press instead. I'm guessing it's the shape of it or something, but I got all 6 holes for both blades drilled out with this with no problem at all. It drilled the holes smoothly and quickly without even damaging the little cutter. And these little bits are made for wood carving! I used to use concrete bits when I was having problems drilling, but these small carving bits seem to work even better. I think it's because they cut more from the side I'm guessing?? Will try to post a picture of the small carbide bit's I am referring to. I used the "flame" shaped one. Worked like a charm! Perhaps there is a way to use just the regular bits to re-drill the holes, but I have not found that method yet.
