Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
rhrocker said:They usually won't last very long, but it can be done with HHS. I like using cobalt drills (screw machine type, much shorter, from places like MSC). I use a lube (I keep a acid brush in a plastic jar, full of tap magic, and swipe the bit now and then), and I "peck" at the titanium until the hole is drilled. Works for me, but i'm betting there's better ways.![]()
Tom Krein said:Jeff,
You really should look into purchasing a drill doctor. Cobalt bits and quality HSS bits are not cheap. You will also not be tempted to keep using a bit once it gets dull. The drill doctors are easy to use and not to expensive. If you still want to throw them away save em up and send them to me.![]()
Tom
