Ok , dual grit testing is about to start :
Dual grit looks to be worth experimenting with if the results By Homeslice can be replicated ..
Just cos one person can do it ! Don't mean everyone can do it ! ( Facts of life )
And I will not be replicating the Homeslice edge , no no no ! I will be using a guided knife sharpening system .
I will do one side ( Guided ) 250 and the other side 1000 . And I will be working towards the blade and not away from the blade ( Like Homeslice )
If the results are poo ! Then I might try sharpening away from the blade to see if there is a marked difference .
I have ordered some courser diamond plate , to see how the hand sharpening goes .. ( I have nothing bellow 600 grit ) ..
So yeah ! It's dual grit playtime ...
I did buy a Spyderco Mule in CPM SPY27 for edge testing , but Huston ! There is a problem ! ( It's too damned good )
SPY27
Guided edge - 500
60 grit grind ( wet stone grinder ) 1150
80 grit grind - 950
That's a lot of rope the SPY27 is eating ! So I chose a few more ( average ) knives for testing ..
IXL ( Japan ) Lock Back from ? ( 80's maybe ) These were cheap as chips back in the day .
Guided edge - 200 Roll
80 grit grind ( Toothy ) 350
Dual Grit 240/800 ... 450
Dual Grit 400/800 ...200Roll
240/240 ... 900 ( No Fail )
Dozier D2
300 Guided ?
60 grit grind 550
Dual Grit 240/800 ... 900 Roller
Mtech MT-987 3cr13mov
Factory - 200
Regrind ( ? grit ) 350 Was it the factory 220 grit wheel ?
Dual Grit 240/800 ... 750 Roller (?)
What we have is some numbers to compare to + various steels ..
The IXL will be the first knife to be dual gritted ! 240 one side and 1000 the other ..
SPY27
Guided edge - 500
80 grit grind - 950
Dozier D2
300 Guided ?
60 grit grind 550
Factory - 200
