"How it is made", prolly the best show ever made for gearheads,
had a segment on how they make steel. Wuz most excellent indeed.
Oftentimes you see a blacksmith forging a bar (making, say,
damascus), working with something like 1"x1"x10" bar.
Now, imagine that bar is 15 feet x 15 feet x 20 feet, being forged
by a gian press, while being held in giant tongs. That's what it looks
like.
Before that happens, they smelter iron and additives in a giant
smelter, with 3 giant electrodes. Must be megaAmps of current
doing the job. As the metal melts, they add alloying elements and
frequently check the resulting "mix" for proper percentages, adjusting
as needed. As they pour, filters will catch larger debri. Of course,
to qualify for NASA, this process needs to be pretty darn clean. It might
have to be repeated few times, to get progressively cleaner, better steel.
Some metals, like brass, can be hardened by "working" it . Steel doesn't
exhibit this feature. Still, when they roll, a lots of stress ends up in the
metal . Also, when hot rolling, exterior layers loose carbon and other alloying
elements. Nasty, hard scale forms. It has to be removed - this makes steel
"decarb" free and it also brings it down to exact dimensions (precision-ground) or just slightly oversized (called just that). Another way to remove the scale is to pickle the steel in acid, but of course it is not precise at all.
When using hot roll for removal-method knifes, one has to be careful not to end up with a warped blade, again due to the stress of hot-rolling being hidden in the metal bar. At best, you will have to spend lots of time orrecting it.
