Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
confused Sir. you agree or think the dymondwood can or cant be dyed?I agree on the ability of the resin impregnated dymondwood to change colors.
I have Rit dyed the sand colored scales for the Vantage 842 (Valox scale ?) , now discontinued, and wrote a story on it in the past.
I went bright orange but some color fading occurs with use and time. You may can find this Vantage on the bay or elsewhere but usually with partially serrated blade. 300
This one was dated 2012, tried a bone Model 55 at same time and wish that I had not. Unsatisfactory color. Was hoping for a more 'camel bone' color. I would name this shade 'gun oil"stained.
So basically what you are saying is that it can be dyed to some extent but then it needs some sort of protective coating over the top to keep it from coming off. Do I understand you correctly?The resin in the Dymondwood can be dyed to an extent. The dyeing is very much surface level in nature; if you sand the surface you will remove the dyed layer. I've used RIT dye to darken my charcoal Dymondwood scales. After this, the exposed wood fibers on the surface of the Dymondwood swell and create a rougher surface than you originally start with. I used a layer of cyanoacrylate as a varnish of sorts, and polished that to give my handles a smooth finish.
I'm not sure how well the process will work with other colors, but I used black dye on my Vantage to darken the Dymondwood. Then II coate with a thin layer of super glue and polished it up.
I learn something new everyday around here.
