Matthew Gregory
Chief Executive in charge of Entertainment
- Jan 12, 2005
There's been a thread recently that, of course, has managed to take on an overall tone of angst and unrest, in fact there's talk of the good ol' days of Bladeforums Knifemaker's section being in the past. I say it's because all the usual topics of pinheads failing to listen to reason tend to hammer the old dogs down, wearing them out prematurely and causing them to leave.
...so i figured I'd start my own thread to discuss an overlooked aspect of what I think knifemakers here (or perhaps I should speak for myself?) are focusing on as critically important to the cutting performance of a knife: edge geometry. We're not talking about spine thickness, or the overall thickness of any other part of the blade except the edge and immediately behind it (I elected to use .050" behind the edge as the point of reference... if you have trouble getting a grip on how small that is, I totally understand... run to the tool box and grab a 3/64" drill bit. The width of the drill bit is how far up the knife I'm measuring).
When I make a chopping knife, my goal is to have the blade offer as little resistance to the material it's chopping as I can without failing (chipping out, cracking, bending, etc). If the angle is too obtuse, it requires greater force to achieve the same depth of chop. Greater force equals more work. More work means less work in a short period of time, or work fatigue... both of which can lead to accidents. It's the big reason folks in the know want sharp knives - they're safer! If you're forced to push too hard, you're bound to make a mistake.
Same thing holds true for any cutting tool... the edge geometry holds the key to what it will cut well! Now, there's other factors involved, that's true... placement of mass in relation to that edge, the amount of leverage created by the blade's point of impact in relation to the hand, even the velocity of the point of impact, the amount of drag incurred by the thickness of the blade (think of it - a triangular cross section is a wedge! You're pushing two surfaces apart with that cross section... if that cross section is thick, it takes a lot more force than a thin one does).
Here's the point I'm trying to make... the task is what determines the edge geometry. Many "test" their knives by cutting things that the knife will likely never see, and somehow by forcing it's way through these tasks (here's the question of efficiency I mentioned above...) this 'proves' the superiority of the knife.
For my own examples, I prefer to make chopping knives with long, widening blades with thin steel and thin edges that are resilient to flexing (something that has more to do with geometry than heat treatment, btw...). Handle shape & ergonomics play a huge role in user fatigue, as well, but all things being equal, a thin chopper will chop deeper into wood and brush better than a thick chopper, which will be predisposed to split the wood rather than chop (unless there is sufficient mass and force applied, it is not an appropriate means of delivery, hence hatchets and axes having longer handles than knife blades).
I never test my edges using hemp rope. I don't know of anyone that even uses hemp rope anymore. 2x4's? Sure, but they're pine... awfully soft stuff, certainly not a good test of chopping ability other than to be easy to get and move around. Maybe I'm strange with my testing medium, but I usually use a well seasoned chunk of hard maple, or oak. Something strong... likely stronger than anything my chopper will be required to face in its life, but not outside it's realm of responsible plausibility.
How have YOU come about your selection of edge methodology? I've just glanced at my own thinking, and about one specific design implementation... what are your thoughts?
