Great! These numbers remove all of the guessing, and it's not nearly as bad as the light gaps looked. The target thickness of the stones before dressing is 6.35mm, .250 inch, so your not far off. Although the ends shouldn't be thinner the difference in your stones will not be noticed while using them. In my tests differences in stone thickness are not noticeable until around .37mm with the 1100 and finer stones, with a 2.5mm, .1", bevel. The 250 or 80 is less sensitive to differences in stone thickness. If these were my stones I would mark the thickest and thinnest spots of the 250 so when I needed to dress it I could focus a little more where it is thick during the next 15-20 dressings and then measure it again. Granted if you are sharpening a lot of knives this will take a year or more because the 250 rarely needs to be dressed, unless you use too much pressure when sharpening. When dressing them you should not remove any diamonds, only resin, so they should not change in thickness from dressing, when done correctly. A maintenance dressing should only take 15 seconds or so for the 650 and maybe 20 seconds for the 250, assuming your using 240 grit, 55 micron, brown aluminum oxide. Other abrasives work too but the brown alox will last the longest before getting ground up too fine to do anything.
Not that this helps you but the 250 and 650 stones I measured at EP last night didn't taper at the ends like yours, but some of the 250s did taper from one end to the other as much as yours but that is from molding not dressing. What caused the thin ends on your stones is a worn-out lapping plate, they get dished from too much work in the middle and not enough on the outside edges. I have already talked with Cody about this this morning and I am going to work with them on this some more.
Out of curiosity have you measured your Venev stones to see how much they vary in thickness?
I don't need proof of purchase, knowing where you got them helps us figure out when they were made. Since Dictum gets one or two orders a month it didn't help too much but from the machining on the back of the 650 it looks to me to be probably from the last batch I delivered to them which was the first part of September.
I am sorry about this but it really shouldn't affect either how the stone works or how long it lasts since you typically wear the centers faster than the ends.
