Can anyone offer some advise please? I recently got myself a wicked edge sharpening system. I tried it out on my trusty cold steel recon-1. I started with the 100 grit and went through all stones up to 1000 grit,following the instructions all the way. Angle was 20 degrees on each side. Here's the problem. The edge does seem "wicked sharp" and polished. It slices paper effortlessly and catches on my fingernail. It grabs the skin on my thumb wanting to slice into it when I test the edge. It seems super sharp in every way I normally test my edges except that it won't shave arm hair now.It just seems to slide off my arm and might take a hair or two with it.I should add that I usually can get hair shaving edges with my sharpmaker. I'm trying to sort this out before I try another blade on the wicked edge. Any ideas why the edge seems so sharp but isn't hair popping?
If shaving arm hair is the only thing it can't do, I generally don't worry too much about it. I don't put too much faith in shaving hairs, as a reliable 'test' of a good edge. Having said that, lots of variables can make a difference:
1. Hair itself is notoriously variable and unpredictable, in how it reacts/responds to a cutting edge. Even the same hair, on different days, will behave differently at times (humidity, and moisture in general, makes a huge difference).
2. Even the slightest rounding or asymmetry of a very sharp edge can make an immediate impact on shaving. This includes the possibility of a very small wire edge which, if it's leaning one way or another, can make hairs just 'slide away' from the edge. One way to look for asymmetry, is to try shaving from each side of the blade. Maintain same direction of stroke, through the same area on the arm, but flip the blade over and check how it shaves from each side. If there's a bit of a 'leaning' wire edge, it'll more likely shave when it's leaning or curled downward into the hair & skin, and it'll slide over if it's leaning or curling upwards. Similarly, you can sometimes feel this asymmetry when testing the 'bite' on fingertips. Turn the blade around, and feel from both sides, to see if it seems duller from one side, than from the other.
3. Edge angle probably makes the biggest difference. There's good reason why shaving razors are so very thin at the edge. I sometimes have trouble shaving hairs even at ~15 degrees per side. When I've gone much lower than that, shaving gets much simpler. A 20/side edge might be a challenge for some, to make it shave consistently.
