HI guys
Finally something I can Add to
I have been running EDM For about 13 years now, and would have to say that in regards to knifemaking EDM is not very useful, The only time I have usd them on a knife was to burn a couple hole after heattreat, wire EDM is nice but slow and expecenive, you would be better off getting peices waterjet cut,
For putting in logo's even with high quaity graphite or copper you would only get one or two good logo's. after that you will start to loose detail, we do mostly automotive parts and burn a far amount of logo type things in molds
like the little horns and airbag letters on your sterring wheels or the lettering around the ignition of your car, they are burned , we use two electrodes for 99% of our burning, on after the other. Not to mention that it would probly take at least a 1/2 to 1 hour to burn a good logo with a knife quaily finish
I have run some well made retrofit machines and they are just fustrating,to run. EDM is a very picky process, servos have to be very accurate or the machines will just not run right, It is a fine balance when you are running a .003-.005 bolt of electricity between steel and graphite. And the finishes were less then desireable,at a .003-.005 gap the finish would be about the look of 120 grit belt, you would have to get down to a .0005-.0002 finsh to look like a 400 grit belt and probly triple the time.(not the belt finish but what the belt actuly looks like)
Another thing to mention is that EDM tend to interfear with radios and T.V. signals and if you don't properly insulate your shop you could have so very angry neighbours,
In closing EDM has is place in the machineing world but just not in the knife world, there are much easier quicker ways to do things, I have played with burning pockets for inlays and a couple othe rthings on the sinkers at work and they are not very time efficent or cosy effecive.
for logo,s stamps would do a much better job and would be alot quicker.
If you do want to use EDM for anything, don't for get the overburn,
that is the amount of gap you are allowing for. EX if you want a .500 hole and you want to run a gap of.005 you will have to cut your electrode at .490 allowing for .005/side overburn and then you will get a .500 hole,
hope this helps , if you have any questions feel free to ask
cya
jimi
