- Nov 27, 2013
This is quickly becoming a very frustrating endeavor. Let me explain my setup first and foremost. The tank is a plastic tote and the anodes are four sections of rebar in each corner. Copper wire is wrapped around each piece of rebar and strung around the outside of the tank, connecting all the anodes. The solution is made from 7 gallons of water with 7-8 tablespoons of washing baking soda(sodium carbonate). Each axe head is wrapped with steel wire and hung from a piece of rebar that I ground the surface down on a bit. For an extra measure I laced copper wire trough the steel wires(above the water) and then clamped the negative batter charger clamp on the copper wire, steel wire, and piece of rebar. The positive clamp from the battery charger is clamped on one of the sacrificial rebar anodes.
I set up an electrolysis tang a few days ago with this cheap car battery charger:
http://www.walmart.com/ip/Schumacher-XC6-6-4-2-Amp-Battery-Charger/15140194
It worked for a day and a half and then just stopped. It removed a nearly all the rust from the axe heads in the tank before it quit. For the life of me I can't figure out what is wrong with this setup. I've brushed off all the rebar anodes in the corners, switched outlets, brought the setup inside and plugged it into different outlets, switched out the old rusty solution with new, nothing. Today I went and bought new battery charger. It's this one:
http://www.walmart.com/ip/Schumacher-Electric-2-6-8-Amp-6-12V-Battery-Charger/25955539
This charger hasn't worked at all. I'm not sure if there's a safety mechanism built into it that's preventing it from working or what. Here are some pictures of my setup(PICS WERE TAKEN INSIDE ONLY TO SHOW THE SETUP. PROCESS IS RUN OUTDOORS):
If anyone has any suggestions or ideas about what I'm doing wrong I would greatly appreciate it. This is driving me nuts.
