- Apr 20, 2022
Howdy all! This is my first post, I'm new here.
So, I have a few friends who have requested kitchen knives, where normally I forge combat blades, so this will be a new challenge. I have a lot of good 5160 steel, so that is what I will be using.
I thought it best to plate the blades with nickel, which should give a lot of protection from rust and such except for the edge of course. Lot's of DIY guides on youtube on how to electroplate with nickel, but every one of them says to first etch your blade in a solution of 50/50 hydrochloric acid/water for about a minute first.
Hydrochloric acid does not seem readily available at local hardware stores, but muriatic acid is. I know that muriatic acid is a diluted and less pure form of hydrochloric acid, but can it be used as a substitute here?
So, if I were going to etch my blade in the 50/50 hydrochloric acid for 1 minute to prepare for electroplating with nickel, any recommendations on what solution and amount of time to etch using muriatic acid instead?
Thanks!
Tony
Thanks!
Tony
