Sure can...I do it all the time. Just use a regular drill bit of the same size as your end mill to start your hole. Drill deep enough to get the shoulders of the drill bit down into your work and then follow with the end mill. This will keep the mill from walking on you.
Phil
Just make a flat bottomed drill.
Drill like Nathan described above, swap to the flat bottom drill and there you have it.
This way will cost less than an end mill too.
Plus you can move around in number, letter, fractional and metric sizes for very little cash out of pocket.
End mills don't plunge very well, the center doesn't cut well and sometimes they get a chip stuck in the center that causes them to wobble around, so you want to drill the tip of your drill bit the full depth of the hole so the mill isn't center cutting all the way down. You probably want a two flute for this. I'd drill slightly under so the endmill can finish the diameter.
The bottom won't be perfectly flat. It will have a bit of a cone sticking out because the bottom of endmills aren't flat.
I'm not following what you mean with flat bottomed drill. Can you explain a bit more? Thanks
Sure, grind the tip of a drill to resemble a flat bottomed end mill.
180 degrees instead of 118 or 135.
Depth of hole is entirely dependent on application.
Rule of thumb is 1.5x diameter in steel gives you all the strength you can get from a bolt.
