I just deleted a long(er?) post on epoxies (aviation & boatbuilder background) but, suffice to say that the epoxies that are sold in hardware stores aren't the best formulations. If it's in a twinned syringe, it's not as good as it could be. A marine supplier might be a better choice for resins, hardeners, and fillers.
To be clear, the time quoted on packaging is not (NOT NOT NOT !!!) cure time, despite what the manufacturer says. It is gel time ('pot life') and it's the point where the epoxy can no longer be deformed without structural damage. For the majority of users of prepackaged products, this is sufficient to do the job while the curing continues. This can take days, or WEEKS for cold-cure epoxies. If the temperature is too low during the cure phase, it may never set up.
A slight temperature change can have exponential impact on cure time. Temperature of the materials being joined (substrate) is so important that the epoxy's temperature is almost irrelevant. Any surface contaminants that are oil or solvent based will also affect the bond (see: 'may never set up', above::grumpy
Epoxies are great stuff, but to discuss the merits of prepack stuff is like comparing different fast food burgers: they all suck, and there's WAY better product available.
Check out the Gougeon Bros. website. They make West System stuff and have great info and test data that (IME) seems to be true in general, regardless of whose resin you buy.
No affiliation here, BTW
I've never worked with phenolic resins (billiard balls, Micarta) so I can't offer anything there.
EDIT: Sorry striper, I'm afraid someone's led you astray - this is probably the most common misconception about epoxies. In an epoxy formulation, the 'plastics' are split between resin and hardener. Changing this relationship changes the final composition of the finished product.
The grain of truth (there always is...) is that this is true with
polyester/vinylester resins where all of the 'plastics' are in the resin and a catalyst is added simply to initiate the chemical reaction that causes the resin to harden. Adding more catalyst to poly resin makes the reaction (exotherm) happen sooner and faster. Not so with epoxies, you'll actually decrease ultimate strength if you alter the ratio.
