All is not lost. If you use the 105 with thickeners, do a proper surface prep with abrasives, rinse with acetone, MEK or denatured alcohol, then use a filler like cabosil & pin or screw the scales in place, I'm going to bet that the knife will outlast you and perhaps a couple more generations. People have used all kinds of epoxy for making knives & there are good, better & best ways of sticking the thing together. As long as your surface prep is done correctly & the epoxy has a chance to set up properly, there shouldn't be any issues.
Where people usually have trouble with epoxy is in the surface prep. They don't abrade the surface, or they don't clean & degrease the parts as they should, then the epoxy gets blamed for the bad joint instead of the way it was used. Any wax, oil or contaminate will affect the ability of the epoxy to make a bond. I'm still using the "hobby shop" slow set epoxy (30 minute) until it's used up & there aren't any problems with it so far.
For sure the West System G-Flex stuff is better in all regards than what I'm using, but I know if I do the surface prep as I should, I won't have trouble later on. I would never rely solely on epoxy to bond metal to wood or micarta, where there is the possibility of a lot of force & impact. In the same fashion, I wouldn't use a mechanical fastener by itself for the same reason. The combination of the two working together is about all that's needed for a good grip which is long lasting. If you rivet, pin or screw things together with an epoxy bedding compound & let the bond set up long enough, it should be there for good.
In the west system literature, the 105 is called "the basic ingredient of all West System epoxy compounds" so I'm going to guess that it's ok to use for a knife as long as it's used properly. Their data sheet says it can be used for coating, laminating & bonding to wood, composite materials & metals. Just my two cents worth.
