- Aug 3, 2008
Hey guys so I finished another batch of grinder last week and have a couple left. I was hoping to get another grinder posted here sooner but I got swamped after the last one I posted. This time around I decided to have the grinders professionally powder coated at no extra cost to the customer. Let me tell you the results are amazing. I wish I would have done this along time ago its way tougher then the paint that was used before and so far the feed back I have gotten is great. I also decided (thanks to another forum member) that it was time to make a 1.5" tooling arm model.(Same as KMG) So now I can cater to the guys that already have a KMG and wish to use there existing tooling with the Esteem grinder. In the past I had made them to interchange with the Bader/TW-90 1.25" tool arms only.
I would like to say to the guys that don't know my work that I take just as much pride in these grinders as I do my knives and hold all the processes involved in building the Esteem too high tolerances and the results are rewarded by excellent repeatable tracking and smooth/quite operation. The Esteem is machined with the use of a manual Bridgeport milling machine in my home shop and the drive and tracking wheels are made at a local machine shop on a cnc lathe.
I have done ever thing I can to make the Esteem a grinder that more affordable then other grinders in it class and make them better at the same time. According to my customers I have seceded buy along shot.
(1).Complete frame with tracking wheel and 6drive wheel.
(2) 5/16 thick steel base plate.
(3) One 1.25 solid cold rolled steel combination tooling arm these are drilled and reamed to either .5" or .75" depending on your choice
(5). Your choice of a 8" contact wheel or Bader style platen
(6).One fully adjustable work rest made from 1/2" cold rolled.
(7). 2hp 3ph1800rpm C-face Toolmex motor
(6). 2hp Teco nema1 variable Speed drive (requires 220 single phase input)
Package as described is $1450
(7). 1.5 or 2hp 3ph1800rpm C-face Toolmex motor
(6). KBAC-27 nema4 variable Speed drive (1.5hp 110v/220v) or (2hp 220v)
[SIZE=Package as described is $1650[/SIZE]
If you have any questions feel free to ask.
Thanks!
Brett
brettandmira@gmail.com
Brett
Thanks!
Brett
Brett
