This is one of my pet peeves. I think most manufacturers do this because rounding surfaces takes extra time and effort, and so, increases production time and cost. IMHO the only parts of a knife that should form sharp surfaces are the point and the cutting surface of the blade. Everything else should have a "melted" soft curve that makes the knife comfortable to handle even when working hard, hand pressed against guard or choil, with thumb on spine, in ice cold weather. My favorite custom maker, Karl Schroen, makes all of his knives this way, and they are a joy to use. Every surface the user touches flows naturally into his or her hand and feels perfect.
I round the spine and, when possible, other surfaces by taking a strip of duct tape, pasting sand paper on the sticky side (abrasive surface out, of course) bending the abrasive side against the squared edges of the spine (or whatever) and pulling the duct tape-sand paper back and forth perpendicular to the length of the square edge until I have a pleasant, symmetrical, soft curve where the edge used to be. Easy to do, and makes the knife hand friendly, like a good tool should be. Doing it by hand instead of a powered grinding wheel prevents heat build-up, which could temper the steel. I don't have a belt sander, but I have heard they are good too if you use an abrasive belt with enough slack to form a curve and run it at low speed to prevent heating.
