Forgive me if this has been discussed before, but my searches on BladeForums came up "page not found."
I'm quite curious if anyone has seriously compared the old carbon steels, carefully heat treated, to the new exotic steels for kitchen knives.
The reason I ask, is that I've been comparing my expensive new Shun's Elite-series SG2 Santoku with (choke!) an old stamped-out $8 Walmart-special chef's knife. My observations:
1) Cheap carbon steel may be soft, but it wears well and the edge straightens up nicely with a strop or smooth steel. Give it points for maintainability.
2) Shun's SG2 powder steel has better wear characteristics, but it needs re-honing once the edge is lost. The edge seems to break, rather than bending over.
3) My old WW2 bayonet in 1095 steel, with its excellent heat treat, makes me wonder if kitchen cutlery in the carbon steels might not be a better choice. I'm thinking mainly, but not exclusively, about carefully heat-treated A2 or 52100.
4) Stainless is nice, but put a patina on carbon steel and it doesn't rust that readily.
5) Debate sharpness and edge retention all you like, but an easily maintained edge matters most for daily kitchen use. I want shaving-sharp knives every time out of the block.
Comments anyone? I'll apologize in advance to the forum's materials snobs. It would also be nice to hear if anyone actually offers quality carbon steel cutlery.
Edit on 10/17/07 to summarize the discussion:
At a terminal bevel of 15 degrees per side, the edge on Shun's SG2 steel at Rockwell 64 has a tendency to micro-crumble. It's still usefully sharp, and continues to be extremely stable and durable. The responses suggest that, go a little steeper, and it won't be a problem. However, the best carbon steels hold an edge at much shallower angles. They also cost less, but can leave a metallic taste on your food. AEB-L steel (I'm not quite sure what it is) got some impressive plugs for kitchen knives, and a steel called SB1 (also at this moment for me an unknown), and gunmike1 gave Takeda's AO an enthusiastic rave. One unresolved point is which steels, like the old straight razors, allow you to let the metal relax, then straighten and polish the edge with a strop.
