- Oct 3, 2003
Experiment and results.
I just got a Beautiful Mini Skinner from Mike (Bark River Knife & Tool) and noticed that the sheath was loose enough to allow the point of the blade to bump against a rivet. To prevent this I wanted to form the sheath around the knife so it couldn't be inserted too deeply. I also wanted to try the leather hardening method found at
http://www.daviddfriedman.com/Medieval/Articles/Perfect_Armor_Improved.htm
More detailed info on the different methods of hardening leather can be found HERE.
I thought I would need to hold the leather in its formed state around the knife while the leather hardens. I was probably wrong on this point. Anyway I hit on the idea of using a vacuum food storage bag system to evenly form the hardening leather around the knife.
Well, I worked. Possibly too well. The whole process took 15 minutes, not counting the hardening time. Here are the steps I took:
However, in typical Tool Man Taylor fashion, I stuck the knife in its hardening sheath in a bag and sucked all the air out with a vacuum food storage bag system set to high. I then let it set in the vacuum for three hours before I opened the bag. I shouldn't have used the high setting, I think. The sheath came out so perfectly formed to the handle that I can see the contours of the finger grips through the leather. But the area around the blade looks, well collapsed is the best way I can describe it.
The leather really did harden well and the knife snaps into the case as if it were well formed kydex. So that part of the experiment was a resounding success.
I think I will try the vacuum pack method again but with less power. I like the way the leather forms so perfectly to contours of the handle but I don't like the way it looks sucked in around the blade. Need a happy medium.
7 hours after removing from the hot water, the sheath is as hard as kydex of the same thickness. I wonder if is as springy? Maybe a possible replacement material?
Here are the pictures:
This first one is the knife and ferro rod in the sheath and the tongue depressors in the belt loop all in the vacuumed and sealed bag.
This one shows the belt loop after the sheath was formed and hardened.
This one shows the leather form fitting to the contours of the handle (good) and the way it sunk in around the blade (bad).
- Soak empty sheath in room temp water for 10 minutes.
- While sheath is soaking, in a separate pot, heat enough water to cover the heath to 180 degrees.
- Remove the sheath from its room temp soak, after it has taken up as much water as it's going to, about 10 minutes. Put it into the now hot water (180 degrees)
- Watch it. Wait for a slight darkening and curling of the leather at the edges.
- At 70 seconds it darkened very slightly and the edges began to curl. Evidently this is the point that the leather starts to change its structure.
- I left it in for another 30 seconds after the darkening and curling started. the longer you leave it in, the more hard and brittle it will become after it sets.
- Remove the hot sheath from the pot, dump excess water from the sheath and insert knife and belt loop spacers. I used wooden tongue depressors for the belt loop spacer, this was to assure there would be room for my belt after the leather hardened.
