- Jun 25, 2013
I just purchased my second high-quality knife (Benchmade). Close inspection of the blade (of both knives) reveals the typical vertical grind lines. The lines are visible to the bottom of the cutting edge. The blades are extremely sharp, able to slice thin or thick paper held in one hand with no problem, and also able to shave hair easily.
This makes me curious about two things when resharpening or "tuning up" a slightly used edge:
1-Why is it necessary to sharpen to a highly-polished edge (and strop to polish the edge even further) in order to get the knife to cut as well as it did with the "rough, unpolished" factory edge?
2-Since the grind lines on the new blades are vertical, or plumb, or consistently perpendicular to the edge of the blade, why does Lansky recommend sliding (for lack of a better term) the stone horizontally when pushing the stone vertically? I realize some overlap is necessary on each upward movement of the stone to prevent unevenly sharpened edges, but it would still be easy to keep the movement of the stones much more perpendicular to the edge than recommended.
Any ideas about:
1-the high polish edge vs the visible grind lines from the factory?
2-the Lansky recommended angle of the stone compared to the factory angle of the grind?
Thanks in advance.
Any ideas about:
Thanks in advance.
