- Mar 22, 2014
That sucks man, guess it doesn't do that very well.
250 dollars or 12, it's still subject to the laws of physics. Either you are correct, and the knife is defective, or the knife is fine, and you pushed it beyond the limit of its materials.Come on man, this is a 250 dollar "survival knife. I wasn't doing anything that should have hurt it.
Those are the only possibilities that exist.
Maybe next time, get a feel for prying with the 12 dollar survival knife before moving to the 250 dollar one! 😂
Im razzing you a bit here, but there is a lesson to be had. An experience is only a waste of you refuse to learn from it.
What you learn is up to you.
I kind of all ready bent it, just prying apart a piece of wood for my fire in the house.
Well that just sucs! Maybe save up for a Busse or Swamprat they have a very good warranty or maybe a knife in 3v that seems to be so tough these days. The Ratmandu seems to be a very popular knife with the outdoors type folks and you may want to check out and is less costly than the one you bent the tip on.I kind of all ready bent it, just prying apart a piece of wood for my fire in the house.
I have busses, swamprats, and a few in 3v. I bought this for the nice compact size. Besides with the edge geometry it cuts circles around my busses. All I'm saying is it should have a more robust tip. The original f1 handled what i did just fine.Well that just sucs! Maybe save up for a Busse or Swamprat they have a very good warranty or maybe a knife in 3v that seems to be so tough these days. The Ratmandu seems to be a very popular knife with the outdoors type folks and you may want to check out and is less costly than the one you bent the tip on.
Mikael & others , We could get into a long discussion on grinding. But to make it short - let's start out with a properly HT'd blade then grind it. Grinding creates heat , best removed with flowing coolant . Improperly done the blade will heat first enough to temper back the blade making it softer and the tip will bend . More heat and the tip will get above the critical temp and harden but will be untempered martensite thus brittle and the tip may easily break ! It would be hard to tell without complete metallurgical exam. Do it right the first time so you don't have to do it again !!!
There ya go man, make it your own. What do you pry so much with tip, I'm just curious not condemning
