- Nov 27, 2013
I’m finally getting after it with my manual mill(Bridgeport/clone J head vertical knee mill) and am having a little trouble finding what speed to run my end mills at when milling g10 and micarta. A lot of the charts that I’m finding don’t have any listings for those materials. I went ahead and mentioned brass and copper just for kicks. Currently I’ll be using a 1/8” end mill, but will also be using 5/32”, 3/16”, and occasionally 1/4”.
I know feed rate is just kind of a “feel” thing with a manual mill, so I’m not so much wanting an answer on that. But any advice would be appreciated. From my understanding, a lot of guides say to mill small amounts of material with smaller end mills. I planned to drill through with a smaller twist drill bit and then open up the hole to the desired size with an end mill. For instance, the one I’m working on now needs to be opened up to .158” x .288”. I was going to drill in twice with a 1/8” twist drill and then get in there with a 1/8” end mill and hog the rest of it out. Maybe 1/16” per pass. Does that sound reasonable? I rounded my tang on top and bottom to match the rounded end mill as much as possible.
I do have an auto feed, but haven’t hooked it up yet. It does NOT have a variable speed, so I’ll be somewhat limited on speeds. But of course I can change belt position on the step pulley for different speeds and have a RPM gauge that’s pretty accurate.
The main thing I’ll be doing is milling guard slots. All the end mills I have are carbide(lakeshore), and most are 4 flute.
This thread is mainly in regards to milling g10 and micarta, but if you had info for brass and copper as well, I’d take it. Hell, if you had a good speed feed chart for steels too, I’d appreciate. There’s a lot of feed/speed charts out there and it’s honestly a little confusing. It doesn’t help that I’m using these small end mills that break so dang easy. Again, any advice would be appreciated. Thanks!
