- Feb 23, 2001
Fire making is an essential skill for the outdoorsman or survivor. Often learned during childhood with backyard sessions involving matches, lighters and combustible liquids, fire making skills include using a variety of tools including matches, lighters, ferro rods and other modern luxuries. Even though most outdoorsman are most familiar with matches or lighters (due to availability), many prefer the trusty ferro rod. In choosing items for kits, considerations are made and could include the following.
Here is a post to examine some of the pros and cons of using each or one over the other.
Matches
Pros:
Easy to use (practice from childhood onto adulthood)
Widely available in drug stores, restaurants, bars, etc.
Lightweight (how much does a book of 20 paper matches weigh?)
Easy to make more water resistant with wax or spray varnish
One-hand use easy with wooden matches
Cons:
Limited water resistance
Deteriorate over time
Single use item (one match = one fire)
Requires a striker unless a "strike anywhere" match
Weak flame in wind
Space used up quickly by wooden matches
Difficult to use in cold conditions with cold hands
Ferrocium Rod
Pros:
High Water Resistance
Multiple fires from one rod
Durable
Highly packable (1/8" bars fit in wallets) and one 3/8" rod (about the size of 6 wooden matches) can light more fires
5000 degree plus sparks emitted
Highly visible sparks at night can be used to signal for help
Cons:
Weight concerns with larger bars
Requires a striker
Requires a degree of skill to use with various tinder
Tinder must be ideal and can be difficult to find if not trained
One hand use difficult if not trained
While this list of pros and cons is not complete, it is a starting point in learning what is an appropriate piece of kit when it comes to these two firestarting methods. There are countless other means of lighting firest but these two are very common. Both methods compliment eachother (try lighting a Backwoods cigar with a ferro rod and no tinder and try dunking paper matches in the drink and still being able to use them after prolonged exposure) and can be carried together.
What are your thoughts and concerns about both of these methods? Post them here and let the discussion carry on.
Matches
Pros:
Cons:
Weak flame in wind
Ferrocium Rod
Pros:
Durable
Cons:
Requires a striker
