Mistwalker
- Dec 22, 2007
The newest model in the Fiddleback mid-tech line came out a couple of months back. I had been looking forward to seeing it because it is a bit bigger than the Bushfinger, but still the same steel thickness, so not as big nor as heavy as the Camp Knife. I like knives in the 5 inch blade range for field knives and all around woods use. They are big enough to do a lot of things with, without being too big to do a lot of other things with I have had this one out on several trips the last month and I am really liking it.
The Duke
Specs:
Overall Length.................. 10-1/4 inches / 26 cm
Blade Length..................... 5-1/4 inches / 13 cm
Blade Steel........................CPM S35VN
Blade Thickness..................5/32 inches / 4 mm
Handle Material..................Crenelated natural canvas micarta
Weight..............................8-1/2 ounces / 240 grams
Sheath..............................Leather pouch sheath with ferro rod loop.
It comes with a good quality leather bushcraft style pouch sheath, with ferro rod loop, from JRE.
The Duke has a hidden lanyard hole which I like. I prefer to be able to use lanyards on larger knives.
It's some what like a big brother to the Bushfinger in profile, with a handle that is a bit bigger in all three dimensions.
The handle is hand tuned for a great fit and finish, crenelated for enhanced grip, and three-dimension-ally contoured for excellent ergonomics.
This knife has excellent balance and handles very well.
Using the lanyard and a rearward grip with snap cuts makes quick work of heavy briers in my way, will let me take down green saplings in a couple of cuts, and makes chopping in harder more seasoned wood much easier with a knife with a 5 inch blade.
The Duke
Specs:
