I've been sharpening a decent number of filet knives in the last month or so. I did a little searching here and found that most people think leaving a filet knife edge sort of rough is the way to go. I've seen advice from 220 grit to 450 (from what I remember anyway).
I've been using the WSKO to do all of these, and have stopped variously at 100 micron (~120 grit), 22 micron (~450 grit), and as high as 4 micron (~1500 grit). Unfortunately, I've gotten zero feedback from my customers, so I have no idea how the perform when cutting fish.
The last one I did, I left at 100 micron, but did 3 or 4 very light, very fast passes, at the slowest speed, on the 5 micron belt, hoping to eliminate the burr, *and* to micro polish the edge. The result was a blade that shaved hair, but not very cleanly, and cut phonebook paper, but was VERY loud and tore it in spots. It felt very sharp and "bitey" to the fingers and sliced into an over ripe tomato cleanly. It would not push into the tomato; only slice. That particular blade had dozens of chips in the edge, and I may have left a shallow chip or two behind which hung in the paper; not 100% sure on that.
I guess I'm asking two things:
1. What finish do you like on filet knives for good performance and long service life between sharpenings?
2. Any thoughts on stopping at a low grit level (very coarse stone or belt) and doing finishing strokes on a high grit level (fine stone or belt)?
Thanks guys.
Brian.
Thanks guys.
Brian.
