- Jun 11, 2006
After my last debacle with the T-88 epoxy 50ml epoxy cartridges I started looking into empty ones. You can find them rather cheep at just over a buck a piece. My thought is buy the T88 in bulk bottles for much less then there cartridges. I would then fill the empty cartridges as needed. I really love the cartridges and the mixing tips. Last night for exzample I was assembling a seax with a few different stacked spacers. After the tip was primed and mixing I just used the tip to paint the epoxy on each part as it was stacked. Then I put the tip into the tang hole and filled it up. Then used the tip agian to paint the tang of the blade and in it went. It's super simple and puts epoxy where I need and the amount I need with no worys about not mixing enough. I love how I can just inject mixed epoxy into small holes and know it's full and mixed.
So after all that rambling has anyone tryied to fill these empty 50ml 1:1 double barrel epoxy cartridges befor? The plugs are not installed and I would think you could fill from the back then put the plug in. Or put the plug in and fill from the front. My concern is the trapped air when filling from the back. Thanks guys
