- Feb 10, 2019
Well here goes... I apologize if a thread about this has been started elsewhere (I looked). I realize this may be opening a big can of worms, but I am curious as to how more experienced bladesmiths went about optimizing their heat treating protocol for a given steel. For sake of argument I am thinking about 52100 since several protocols have been proposed in this forum. The stickies provided in this forum by Stacy and Larrin's recent article were very informative. These links seem to be a good place to start, but there was little consensus between different recipes. With so many variables to test and fine tune this seems like a daunting task. Where does one begin? What is most important? How do you test your blades, assuming you do not have a laboratory at your disposal? First off, I would not attempt a low tech heat treat on such an alloy steel, so sufficed to say I have a Paragon HT kiln. The first, obvious step before applying any of the above mentioned protocols would be to calibrate the thermocouple. Before I get ahead of myself, perhaps it would be best to define the intended use of this steel. I do not believe there is one perfect steel for all applications. For a relatively rich forging steel such as this I personally would not make blades over 5 inches. For larger blades that take a beating I would probably use 5160 or L-6. Below is a short list (not comprehensive) of the variables that may or may not be critical:
Steel Supplier
Initial State of Steel
Forging Temperature
Forging Time
Normalization Temperature
Normalization Soak Time
Thermal Cycling (grain refining) Temperature(s)
Thermal Cycling Soak Time(s)
Number of Thermal Cycles
Annealing Steps
Annealing Temperature(s)
Annealing Soak Time(s)
Annealing Cooling Rate(s)
Degree of Finish Prior to HT
Stress Relief Temperature
Stress Relief Soak
Austenizing Temperature
Austenizing Soak
Oil Type
Oil Temperature
Time in Oil
Number of Hardening Cycles
Cryogenic Soak Time
Tempering Temperature
Tempering Time
Number of Tempering Cycles
Time between HT Cycles
Some of these, such as steel supplier, may be treated as constants (at least initially) but which? Finally, how did you determine when the end product was good enough to pass on to customers? I realize this is a lot.
Steel Supplier
Forging Temperature
Forging Time
Annealing Steps
Stress Relief Soak
Austenizing Soak
Oil Type
Oil Temperature
Time in Oil
Cryogenic Soak Time
Tempering Time
