1) If it has big cracks, fill those with structural epoxy that is tinted to match the ivory color - or use a contrasting darker color. A darker fill can make a seemingly worthless set of scales or handle block really pop.
2) If the mammoth is full of big cracks and de-laminations, a trick is to completely fill the voids with acrylic casting resin. You can use clear or a tinted resin. The knife suppliers sell such resins for making. Inlace works well for this type of fill.
Tape the outside of the tusk piece with several layers of masking tape, making a funnel on the large end of the splits/delams. Cover the small end with tape too. Pour the resin in from the large end of the splits/delaminations. Vibrate the piece as you pour to get the air bubbles out.
3) If the cracks are medium size, use thick or medium CA to fill.
4) If it has small cracks or is porous, wait until after sanding to near final finish, then flood with thin CA and sand off several times to fill all voids.
5) The main thing about working mammoth is to go slow, use fresh belts, AVOID HEAT BUILD UP, and finish by hand sanding. Buffing lightly with white rough and a linen buff will make it glisten, but don't burn the ivory by running the buff too fast or buffing too hard. Just hand sanding to 8000 with the 3M colored sanding sheets will leave a perfect gloss finish.
