The Warrior
๐ฎโ๐ณโ๐ธโ๐ฆโ๐ณโ๐ชโ ๐ปโ๐ฎโ๐ฐโ๐ฎโ๐ณโ๐ฌโ
Moderator
- Mar 11, 2011
Hopefully there's not already a thread like this. Here's the fire pistons I own. The first is a traditional string gasket Cocobolo piston by Darrel Aune of Primal Connection. The second is by Jeff Wagner of Wilderness Solutions, and is a traditional string gasket made out of buffalo horn, with a Cocobolo lanyard ring on it. The third piston is Cocobolo, with a delrin rod and o-ring gasket, also made by Jeff Wagner of Wilderness Solutions. Les Stroud uses his pistons. The fourth is also Cocobolo, iirc, and is a James Spily custom. Brass rod and o-ring. It has a longer shaft, and probably works the best out of all of them. The last one is made by Rose Mountain Fire Pistons, and is made out of Red Stag. It too has a brass rod with o-ring. This one works quite well too, with a longer stroke, but the unusual end makes it a little harder to get chaga, char cloth, etc, to stay in.
Let's see those pistons!
