Any VFD for our purposes will be putting out 230vac, whether 110 or 220 input voltage. The problem for many makers is having 220 available in their garage or tool shed. A kbac 27 will give you up to 1.5hp and run off of 110vac, but it is a tad high on price. The cheapest Chinese vfds, 1.5-3hp run on 220vac. I believe TECO has some that run 110 or 220, but they only go to 1hp, which, honestly, for direct drive, you could probably get by fine with.
That said, the best option if you could have anything, would be a 2-3hp vfd and motor on a 220vac circuit.
Cheapest option for 110 vac, however, is step pulleys OR, a 1hp vfd and motor. Next best option (but more money) is 1.5hp with a kbac 27 running on 110vac.
Thanks for the straightforward explanation.
A 220v socket is out of the question, so there goes the cheapest VFDs. Although I am seeing some around $150 that are 115 in and 230 out, 1hp. I'm looking at a TECO right now with the following specs in the description:
- Cost effective drive solution with wide range of programming capabilities
- 115V 1-Phase Input, 230V 3-Phase Output
- 1 HP Constant Torque (4.3 Amps)
- V/F mode or Sensorless Vector Operation
- Simple to program with parameters grouped by function type and purpose
FACTORY NEW TECO VARIABLE FREQUENCY DRIVE
*USE THIS DEVICE TO START/STOP & CONTROL THE SPEED OF A THREE PHASE MOTOR*
1 HP INPUT VOLTS: 115V 1PH OUTPUT VOLTS: 230V 3PH OUTPUT AMPS: 4.3 ENCLOSURE: IP 20
TECO CAT#: L510-101-H1 (Replacement for the JNEV-101-H1)
Dimensions: Height: 5.67" Width: 4.65" Depth: 5.8" Weight: 5 LBS.
Applications: - Mixing - Fans - Pumps - Small Conveyors - Treadmills - AC Contactor Replacement - Packaging - HVAC - Machine and Tooling
Features: - Speed Potentiometer (speed pot) - Compact Design: the L510 has a small footprint and accommodates DIN rail mounting as an option - Simple to program with parameters grouped by function type and purpose - 150%25 overload - 0-650Hz - Digital Operator: 5 digit bright LED readout - Diagnostics and parameter configurations - Leakage current prevention via capacitor switch - Sensorless Vector , auto-torque boost, V/F control - Power loss ride-through - Teco-Link configuration software for on-line monitoring, programming, and operation via built-in RS485 - UL, cUL, and CE approved
If this would work, then that price is fine with me. 3ph/1hp motors aren't all that much more expensive than the 1ph/1hp that I bought anyway, and if I have to spend an extra $50 to get a full speed range and a simpler build on a machine that will last me decades to come then that's money well spent.
The outlet in my shed is 15a but there are 20a outlets within reach of a short extension cord if need be.
