First Impressions - Boker VoxKnives Gnome
I recently purchased a Boker VoxKnives Gnome neck knife. It is made in China from 12C27 steel. This tiny little thing sells for $20-$25 online. Mine is serial #0263.
Size - Small!
At 4" overall, the entire knife is slightly longer than my middle finger, and a little taller than a quarter. The whole knife is as long as the handle on a Cold Steel Spike. It is moderately thick and compares to full-sized fixed blades, but is thinner than an original Spike. The micarta handles and holes kind of give it the look of a micro Busse.
Ergonomics - Very Good (for the size)
This knife is so little that it doesn't have a handle per se. Holding it is a lot like choking up on an ordinary fixed blade using the choil, but then having nothing behind your index finger. Your middle finger rests against the back end of the knife and your thumb presses against the back of the blade. This arrangement works pretty well, and is as good as it gets for something this small. You can also put your middle finger in the choil and run your index finger along the top of the blade.
I doubt you'd want to chop down many trees with this knife, but it's pretty comfortable.
Fit & Finish - Good
With a $20-$25 street price, the quality is entirely acceptable. My blade grind is a little uneven, there are some invisible burrs that catch my fingers, and the sheath doesn't fit well. Actually, the sheath feels like an afterthought, as the fit is both too tight (it was grinding out plastic bits at first), and also kind of sloppy once the knife is inside. Plus, the sheath is squared off and too bulky for the size of the knife.
Blade/Cutting
The blade is hollow ground and the geometry looks good, but I haven't cut much with it yet (hence calling this first impressions rather than a review).
Overall - Very Good (but final judgment TBD)
This design makes sense in a lot of ways for utility, detail, and package opening tasks. More info after I've had a chance to use it. I wish it was marketed as a utility knife rather than a neck knife, and sold with a better sheath. My wife doesn't like most of my knives as they are "too dangerous," but this one is cute even for her. She also likes the Mini Cooper... :o
I used my gnome (serial #0059) yesterday at cabin. It make decent whittling knife and also easily opened all possible pacakges for grilling. Its really handy, light and durable necker.
I ordered my back in February, along with the Rhino. I am still waiting, and waiting, and waiting!
Update - Cutting Report
Ok, now I've had a chance to cut some stuff with the Gnome. Here are the main points:
  • As typical for wharncliffe blades, it does a great job with precise detail work and doesn't drift.
  • I tend to put both my thumbs on top of the blade and push cut when there is much resistance. As only one finger can grip the handle, difficult materials can make it torque in your hand. This can result in two-handed use where I'd use one hand with a longer knife.
  • The short length and thick blade makes it difficult to start cutting paper, but then cuts easily with a sawing action.
  • The rounded off top of the blade makes this virtually a safety knife. It isn't the best for getting into small spaces/letter opening, let alone snagging things with a quick swipe. I see zero functional overlap with the Cold Steel Spike (which is a slasher).
  • I still dislike the large and sloppy factory sheath. Marketing seems to have driven this to being sold as a neck knife.
Overall:
A nice product and I'm glad I got it. Very good for the price. The Gnome is a niche utility knife best used for detail work and the rounded tip helps avoid accidental cuts (e.g., people, inflatables). It should have shipped with an easy-access belt sheath.
I know this thread was started a while back, but I just ran across it and thought I'd share
some things I did to make my Gnome more "user friendly".
First of all I added a fob to give me a little extra length to grip on to.
Then I added some paracord through the eyelets and put a carabiner through it. The carabiner allows the
knife to hang upside down for easy draw.
Or if I want, I can run my belt through the other side and wear it right side up.
Not that pretty but it gets the job done. :D
