As a self proclaimed biggest fan for CS folding knives, I'm usually extremely excited for any new models, even the Frenzy which is bigger than anything i'd ever buy. However, IMO this one looks meh for a few reasons:
1. I would much rather take just a normal opening hole. Honestly i've been praying for CS to release more opening hole knives, this is one of the reasons why i like Tuff Lite so much. However, this one seems overdone. Not sure if this is because they might run into trademark issue with Spyderco? Luckily the "eye" is made of brass and not steel, so i can already see myself removing it.
2. The blade to handle ratio seems WAY off, probably worse than the Ultimate Hunter. If you cut the blade from the picture and superimpose it on the handle starting from the pivot side, the blade probably terminates at the 3rd finger groove. I know that CS tends to have lower blade to handle ratio due to having a bigger tang for the Triad lock, and i like it, but this looks too disproportionate.
3. The pocket clip is an absolute deal breaker. I wished they would use the normal clip like on the Lawman or Recon 1. Why make is funky and incorporate the lanyard hole with the clip? The 3rd screw at the bottom is totally unnecessary IMO and assuming this is an 8+ inch knife, you will have probably 3/4 inch of handle sticking out of your pocket. They seriously should redesign the clip, it's one of the most horrible i've seen...
No offense Cold Steel & Mr Demko, i really love your design and i have bought every folder model less than 4 inch blade since 2010 when you guys started using Triad lock, but IMHO this is really a big miss for me... But hey, i'll probably still gonna buy both Spear Point and Tanto version. On the plus side, i'm glad that you guys are starting to use S35VN. Also the Tanto seems like it has a flat grind, like other high end manufacturers i.e. Benchmade & ZT use.
Please, if there is still time, fix that pocket clip......
