Looks good, JT. I'm guessing CNC mill with a ball nose cutter?
Next one, try and relax the rate of spiral. That one looks to be about 540 degree twist - six flute. Try 360 degree twist- four flute next time. It is more hand friendly and looks better. When the one you are doing is on a blade, you will see that it looks sort of like a screw, not so much like fluting.
Another thing that helps the finished look, is to carry the twist wire ( and the flutes) all the way to the ends, and turn them under,so they just disappear. With a well fitted spacer bolster and pommel, it looks almost like they come out of them.
Emre,
When I lay out a flute, using a pencil, I divide the blank into four longitudinal "quarters", at 90,180,270,360. I then make three circumferential rings at 1/4,1/2,3/4. I start the spiral at the top, going from intersection to intersection as the piece is turned, marking the spiral. A 1/4" wide strip of flexible plastic makes this easy to draw. Once all four flutes are sketched in, start with a round rasp/file, and make the preliminary cut in the center between the lines ( you want to leave the lines till the end. Switch to a half-round file/rasp once the starter grooves are set. Slowly make the flutes, doing them a little at a time, until there is a 4mm ridge between the grooves. The original lines drawn should be down the center of this ridge. Once all looks right, carefully make a groove down the line with a 3 corner file or a knife edge file. Deepen this to make the wire channel for the twist wire. It should be about 3/4 the depth of your wire twist, and just a little bit narrower than the wire twist. So, for example, if you have a twist of wire that measures 2mm, the groove should be about 1.9mm wide and 1.5mm deep. That should be just enough to allow the wire to sit snug when wrapping it, and set tight with a tap from a mallet. Remember, it is easier to take a little more off later.
Now, sand the main flutes with a piece of paper wrapped on a dowel until it comes about 1mm from the wire channel.There should be a small flat ridge on each side of the wire twist. In the final sanding, the two "lips" ( on each side of the wire groove) become slightly rounded, creating two half round "beads". The final look is - Flute, Bead, Wire,Bead, Flute...
When the handle is ready to wrap with the wire twist, deepen the wire groove as needed to make the wire twist sit so it looks right.
Jigs and all are nice, but all they really do is provide the reference lines and hold the handle for you.
Stacy
