- Dec 20, 2005
If anyone's interested, here's how I do it:
Materials required:
1/4" seamless 303 stainless steel tubing (I got mine from onlinemetals.com)
Wood screw heads (Head width = 0.302", shaft width = 0.129")
Hardened "hex key" heads (Head width = 0.376")
Countersink
Lubricant (I use olive oil mixed with WD-40)
Bench Vice
Hacksaw
Tubing Cutter
Digital Calipers
Black Marker pen
(Assuming you've already finished the scales and countersunk the holes in the scales -I go 5mm below the surface).
1. Measure the width of the handle with the calipers (blade, and scales), mark the tubing with the marker pen, scratch the width using the calipers, and cut the tubes to this width (using the tubing cutter).
2. Hold each tube with a pair of vice grips and using a drill press with a countersink bit, countersink the inside diameter of the tube slightly to aid in flaring.
3. Cut off the heads of the bolts, leave a little to fit inside the tube -but not so much as to touch each other.
4. Apply lube (this is essential, otherwise the tubes may not flare and will split) using a Q-tip to the inside of the tube and around the base of the screw heads.
5. Press the 1/4" tubes into the handle and through the scales using the vice. Make sure they're even, this can be done by feel.
6. Put the smaller screw heads on each side of the tube.
7. Holding the screw heads in place, slide it into the vice, tighten vice. I tighten as much as I can, without a cheater bar. If you can crack micarta scales by hand -you're a monster!! (I haven't tried this with wood scales yet, but practicing on pine, I haven't cracked it).
8. This sets the rivets. Repeat Steps 6 & 7 using the wider screw heads for a proper and clean flare.
9. You're done.
10. Wash off the oil with soap and water.
Hope this helps anyone wanting to do this. If you find a wider screw head with the same shaft dia. you can do this in 1 step, but I haven't had any luck in finding one.
Takes a little practice, but is a strong and affordable way of fixing handle scales with no epoxy. I used to use Loveless bolts, and still do, but this way is quicker and just as strong. I would recommend that you try it on a plank of wood first.
The cool thing is that you can drill out the rivets at any time and replace the scales, so if you're into changing colors of scales or anything else like that, this works well.
P.S. If anyone's wondering, I posted a thread asking if this is trademarked by Busse Combat, as this style of rivet is what they use, and Jerry let us know that it isn't trademarked and okay for other makers to use:
http://www.bladeforums.com/forums/showthread.php?t=469956
Materials required:
Countersink
Bench Vice
Hacksaw
Tubing Cutter
Digital Calipers
Black Marker pen
9. You're done.
