Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The rules for The Exchange can be found here. Please read and follow them. Stop using Paypal Friends & Family and follow our best practices to prevent getting ripped off or having a bad deal.
This has been a bit of a hard month.. The A/C Compressor and Condenser went out in my truck, had to take one of my dogs to emergency, and had some dental work myself. Looking to move a few items to help recoup what was spent. Thank you for looking.
Sale Terms:
US/US territory shipping only
Items: 1-3 Priority Mail shipping
Items: 4-11 First Class shipping
Paypal Purchase of Goods Option (no gift payments please)
I reserve the right to refuse sale at my discretion
1) Lux-RC Minion R1 Mule Triple 3000K, secondary red, heat anodized head Emitters: Triple XP-G2 (3000K warm white) with secondary red led.
This is one small flashlight that is just slightly bigger than the battery that powers it. The body and head are made out of stainless steel, while the tail has a strong magnet. Has not been carried by me but I am the second owner and it may have some light handling marks, as it is a polished finish. The head was heat anodized by Serge himself.
The Minion R1 is programmable at the Lux-RC website using NXS_R1. The thermal adjustment limit was not adjustable through default settings but there is a trick to allow it to be adjustable - I have adjusted it to a low setting for earlier thermal adjustment on max output. This gets hot fast but soon adjusts itself as it heats up.
Includes: Box, function card/instructions, light, 1 x 18350 Aspire IMR battery.
This was modified by vinhnguyen54 @ CPF and purchased during one of his sales. I don't believe he uses these Samsung LED's anymore, as he told me SST20 perform better in every way.... but this has generous output and a beautiful tint. This light was used sparingly around the house and is in excellent condition. It uses a 21700 (included) and charges via USB-C. Has stock UI.
Modes From off: Single press to turn on, single press to turn off
While on: Press and hold to cycle through low, medium, high
While on or off: Double press goes to Turbo
While on or off: Triple press goes to Strobe
While off: Press and hold to access Moonlight (Acebeam's definition of Moonlight is similar to Fenix's lol)
While off: Press and hold coming to Moonlight, and continue holding to electronically lock the light out. Press and hold to unlock the light.
Includes: Box, instructions, holster, charging cable (you must supply your own brick), 21700 battery, and 18650 battery sleeve to reduce rattle should you want to use an 18650 over 21700 battery. Does not include card from vinh, as none was included with this one.
This was modified by vinhnguyen54 @ CPF and purchased during one of his sales. Tint is nice. Bezel of light indicates 1000 lumens, but this was for the stock emitter. Turbo here is approximately 600 lumens. This light was used sparingly around the house and is in excellent condition, however a new battery may be needed. Will work with any 16340, however must purchase a Olight 16340 (ORB-16C05-10C) to use the included charging cable. Has stock UI.
While on: A quick press, immediately followed by a press and hold to set the timer (automatically turn off). Can be repeated again to set from 9 minutes or 3 minutes
Includes: Box, instructions, soft pouch, lanyard, charging cable, battery, and card from vinh.
4) Thrunite T1 Neutral White
Emitter: XHP50 (neutral white).
Purchased brand new used sparingly around the house. Stock UI.
While on: Press and hold to ramp from low to high and vice versa (it automatically loops)
While in Moonlight: Press and hold to electronically lock the light out. Press and hold to unlock.
Includes: Box, instructions, lanyard, spare o-rings, 18350 battery, and proprietary micro-usb charging cable (this has a longer connector than standard micro-usb cables).
5) Liger Gun Belt Size 34 (1.25" width) I picked this up about three years ago and have used it almost every day since. There is wear shown in the first three holes. The buckle has a couple of small dings. Nothing major and this will still function for years to come.
Biothane belt material, made out of a high-strength resin-embedded polyester fabric core. The buckle is made out of T6-6061 aircraft aluminum, while the rivets are 3/16" stainless steel.
6) PJ Holster Tuckable IWB Kydex Holster: Beretta Nano
Handiness: Right Handed.
Belt Width: 1.25"
Belt Attachment Type: Over the belt clip on Loop
Holster Cant: 15 Deg
Tuckable: Yes (shirt can be tucked while conceal carrying)
7) PJ Holster Tuckable IWB Kydex Holster: Glock 26
Belt Width: 1.25"
8) PJ Holster Tuckable IWB Kydex Holster: Kahr CM9
Belt Width: 1.25"
9) PJ Holster Tuckable IWB Kydex Mag Holster: Kahr CM9
Handiness: Left Side Carry, Bullets facing backward.
Belt Width: 1.25
Belt Attachment Type: Behind the belt J hook (IWB only)
Kydex Thickness: 0.80"
10) PJ Holster Tuckable IWB Kydex Holster: Sig Sauer P320 Compact
Belt Width: 1.25"
11) PJ Holster IWB Kydex Holster: S&W M&P9c
Belt Width: 1.25"
Belt Attachment Type: Over the belt clip on Loop (clip reinforced/thicker than standard)
Tuckable: No
