Sold some knot work to buy this Olight S1 Baton, which is going on my keychain for edc, replacing my Acebeam L10. It's shorter but thicker than the L10, and smaller than the Olight S10 I have tucked away in a gadget drawer that seemed just a tad too large for keyring duty.
I like the S1 features and the ability to use rechargeable RCR123/16340 means saving money on batteries, with the slight downside of shorter runtimes than using primary CR123A cells.
As soon as it arrived today I used a scrap length of 0.9mm orange cord to tie the Spanish ring accent knot around the small groove at the head end of the light. I'll use the same attachment clip on my keyring that clipped to the split rings I've added to other flashlights for quick detachment when necessary. I like the titanium, brass, and copper versions, but decided to go with the basic aluminum body.
Specifications:
* LED: CREE XM-L2 CW
* Battery Run Time:
+++High: 500 lumens- 300 lumens, 1.5 minutes + 90 minutes
+++Medium: 80 lumens, 6 hours
+++Low: 8 lumens, 40 hours
+++Moonlight: .5 lumens, 25 days
* Supported Battery: 1 x CR123A, 1 x RCR123A
* Maximum Beam Distance: 120 yards / 110 meters
* Maximum Beam Intensity: 3000 cd
* Dimension
+++Length: 2.4 inches (61 mm)
+++Diameter: .83 inches (21 mm)
* Weight: 1.06 ounces (30 g) excluding batteries
* Waterproof: IPX-8, 2 meters up to 30 minutes
Features:
* Magnetic tail cap for standing or attaching to magnetic surface
* Built-in timer to turn the light on for three or nine minutes
* Simple single-button side switch for all functions
* No-slip pocket clip
* 1.5 meter impact resistance
* Stainless steel head and switch binder ring processed by PVD technology
* Recessed silicon switch to prevent accidental operation
* TIR lens to create a balanced beam
* Made of A6061-T6 aluminum with class-III anodizing
