- Jun 3, 2019
so far I have been doing pretty long kitchen knives with relatively low curvature edges and full flat grind bevels - so this question has not really arisen for me yet. I am about to start grinding a much shorter length skinner for a friend where the geometry of the thing has me thinking about this - and a review of online videos makes me think I have the answer - BUT the videos are not exactly clear....
Here is the question: Walter Sorrells is pretty clear that when doing a Scandi grind, you set your angle, then rotate the blade so that the belt is always running perpendicular to the edge as you move down the edge and around the curvature of the blade. Ok, clear... and this is pretty much what I have been doing - but I think is wrong for a true full flat grind (but with my low curve edges it has not stood out as a problem.
On the other hand - for a true full flat (and saber) grind, Sorrells and others (Ekim for example) say "set the angle, then pull horizontally across the belt". Visually, they do not appear to rotate the blade as for a Scandi grind .... but the geometry of the edge against the belt gets really weird (especially for a highly curved edge) if you just continue to pull the blade across the belt without changing the orientation of the blade relative to the belt.
What makes sense to me, and what I **think** I see Sorrels and Ekim doing (but they do not SAY it) is that as they pull the blade across the belt, as they come to the curved part of the blade, they keep the current "bevel" angle constant, BUT they pull the handle "towards" themselves so that contact between the edge of the blade and the belt is kept constant.
Is this correct? this makes sense to me when you are freehanding .... but how on earth would you make this work when using a jig????
