Joe, a 9" Hossom fighter just sucks on wood.
Edit begins here:
What I find wrong with this whole question of "what is better" is that it is an incomplete question. It neglects the "for what" part of the equation. I've never built a knife to cut frozen vegetables. I make fighters and hunters for the most part, and for those purposes I find my hollow grinds works well, both to create the edge I want and to produce a knife that moves and handles in the manner I consider important. The camp knife above was purpose built to chop wood, using the most efficient grind I could come up with. I suppose it will also cut frozen veggies and other stuff, but it would make a lousy fighter and I doubt it would be much good for skinning deer. I don't make utility knives either, but I suppose one could use almost any grind on one and it would produce a useful knife.
I find nothing wrong with flat grinds, and until I did the camp knife a few months ago, I routinely referred buyers to other makers who did flat grinds for anything that was to be used on wood or similar hard substances. A flat grind works extremely well there for all the reasons given. I have trouble with the idea that there are no further answers to be found on how knives can be built or how blades might be shaped for more efficient cutting. If I believed that were true, I'd probably quit knifemaking, since the quest for a better knife is what makes this job interesting. There really are no pat answers in knifemaking, and that's good.
For the record, my hollow ground fighters have endured stress testing designed to test how a fighter should perform and have uniformly passed everytime out. The exact same series of tests, run in parallel on flat ground blades of 5160, A2, and 1084/15N20 Damascus failed in the same tests (chipped edges and broken points). In all cases, however, the makers of those flat ground blades passed the same tests on resubmitted blades produced once they had a better understanding of the demands. That's what the craft of knifemaking is all about, and that's also why broad generalizations are IMO inappropriate. There is no "best" without a much more refined definition of "for what".
