Hi!
I know that this question has been reviewed many times and I spent countless time reading about it but my own experience makes me confused.
For what I read, the general consensus is that hollow ground blades makes better slicers and flat ground blades better "cutter" (meaning deep cut).
My two favorite EDCs are a case large stockman (6375) (hollow on all blades) and a victorinox pioneer x (flat ground blade).
After various tests (bread, meat, dry sausage, tomato, cucumber, wood, paper, whole post-it block, cardboard, plastics, rubber...) I found that the flat ground blade of my victorinox performs better on all material tested, doesnt matter if I slice or cut.
I was even more confused after the last test (cutting through a whole post-it block) because before the test my stockman was hair shaving sharp while the pioneer was just sharp (cut easily through paper but not hair shaving) but the pioneer anyway went through the paperblock like butter while I had to apply considerable pressure on my stockman.
I believe the steel is not the issue as I read that case truesharp and victorinox stainless are roughly similar in term of performance.
So does blade geometry really explain these results or do I just suck sharpening hollow blades?
Thanks!
Thanks!
