- Oct 18, 2001
Shouldn't it be possible to make a practical, comfortable folding knife that could stand up to bushcraft/survival use with few compromises?
I've been mulling around this idea for about 11 years now. And I've finally found a way to make it happen.
Here's the story that started it all:
So I did.
I've built a bunch of prototypes of this design along the way....from wood dummies...to aluminum trainers...to mild-steel mockups...and now I have finished the final prototype.
I've been fielding requests from customers to make a folding scandi-grind knife for nearly as long as I've been making scandi-grind knives. But I didn't want to just make another tactical folder and simply scandi-grind the blade. I needed it to be something special, something unique, something well-thought-out. That's why it has taken me so long to get this far. And even now I have been working through prototypes...and am finally finished.
Here is a picture of the final Prototype!
10 reasons this folder is different than your everyday tactical folding knife:
There are plenty of great tactical folders out there. I have purchased and collected many myself - both custom and production knives. I really don't have anything negative to say about anyone else's work. I just feel there is a "gap" in the market for a usable, comfortable folding bushcraft knife and I intend to fill it.
Thanks for reading!
Dan
KosterKnives.com
Edited to add:
1 -you can pre-order here =====> http://kosterknives.com/pre-order
It's just a "show of hands". No commitment. No obligation. I will contact everyone on the pre-order list when this is ready to go.
2 - Specs:
Liners will be made of 0.095" thick Titanium
Blade is 3.7", 0.125" thick CPM 3V with Scandi grind set at 13 degrees
Handle is 4.8", made from 3/8" thick material with palm swell/contouring
3 - this knife is intended for all bushcraft use except heavy batoning or spine-whacking
4 - Pricing is $365 because this knife is for 24/7/365 use - hard use, all day, every day, all year long.
5 - Options available:
The following options/add-ons are available.
Handle Options
Sheath Options
Titanium Finish Options
Misc Options/Add-ons
I'm open to suggestions - feel free to email me any requests for options you'd like to see added.
I was camping with relatives who knew I was into knives. I pulled out a knife I had made and gave it to someone to do some woodcarving, whitting, fire-prep, etc. They loved it so much they held onto it the entire trip. So, naturally, I had to go to my backup - which at the time was nice folding knife. It had a hollow grind but a thick edge that I put a large secondary bevel on and it push-cut like a dream. So I figured I'd have a pretty good time testing it out. It only took about 15 minutes before my hand was starting to hurt and then after 30 minutes of constant use I had to put it down. Calluses aside, I was in serious pain. Fast forward a couple years to a passaround I participated in here on Bladeforums with the Hossom Retribution #1 & #2. I was very curious to try these out because it was a rare full-sized handle on a folding knife. Aside from the handles being too short on one and too long on the other, I found the overall size very comfortable to use. However, it lacked a full-length backspacer and the crazy curves in the blade and handle made it impractical for serious bushcrafting.
Over the years I have been designing and redesigned this ideal folding knife in my mind and in CAD. Then I had a Eureka! moment. Here's this bushcraft knife that I've sold for a number of years now, have made various versions of, have tweaked the design carefully since its inception, have sold 800+ of them....and it's staring me in the face screaming "Make me into a folding knife!".
So I did.
[*=left]0.125" thick 3V steel, true scandi grind (flat) set at 13 degrees, hardened to 59-60 HRc, tumbled finish on flats for durability, riding on IKBS bearings for super smooth action
[*=left]Frame-Lock type construction under a full size handle. Typically you have either a thinner liner-lock with scales, or a thicker frame-lock. This has both a thicker frame-lock as well as scales. Maximum comfort and stiffness/rigidity.
[*=left]Full length, full width, "upside-down egg" cross-section handle. No squared edges - everything is rounded and contoured. Thicker on the top for rolling in your hands while carving, thinner on the bottom for leverage.
[*=left]Squared off spine with thumbgrooves for striking a firesteel
[*=left]No thumbstud to get in the way of woodworking cuts. Anyone who has used a folder for woodcarving, making traps, kindling-sticks, etc. knows what a pain a thumbstud can be. Instead, will be a nail nick or milled slot.
[*=left]Hidden pivot pin to keep things clean physically and visually. Also, for comfort. No bolster either. Keep it simple, practical and straightforward.
[*=left]Maximum blade/handle ratio. No compromise. Blade tip goes all the way to the back of the handle.
[*=left]No pocket clip. A clip is the most uncomfortable part of a handle on a folding knife. It only takes about 10 minutes of serious use before your hand starts to get torn-up and many of my bushcrafting customers and friends are taking the clips off of their folders now anyway. I'm not against a clip on a tactical folder. Just not on an "actually-will-be-used-for-bushcrafting-and-survival" folding knife. I will have an optional leather and/or cordura pouch made to hold the folder with a firesteel loop along side it as an add-on.
[*=left]Comfort and usability without sacrificing quality was the #1 goal. Not looks. Not money in my pocket. Not "building my reputation" or prestige. Not for pimping. Not to drive the secondary market. I just wanted a knife I could actually take bushcrafting and not have to compromise comfort and usability. All the same quality materials as my fixed blades....it just folds up for convenience. It doesn't matter to me if I sell 10 or 1,000 of these. It's the right thing to do, and this is the right way to do it.
[*=left]No exotic materials. I imagine at some future point I may consider dressing up one of these for fun. But for now I have no desire to add damascus, mokume, mammoth tooth, and so on. Those materials are highly impractical out in the field where you may regularly encounter poor weather conditions, changes in humidity, impact from use, etc. These will lock up rock-solid, have impervious materials and be ready for constant (not occasional) use. They will be made from the same materials I use for my fixed blades.
Thanks for reading!
Dan
KosterKnives.com
Edited to add:
2 - Specs:
Handle Options
- Natural Canvas Micarta (+$0)
- Black Canvas Micarta (+$0)
- Green Canvas Micarta (+$20)
- Black G10 (+$30)
- Red G10 (+$30)
- Blue G10 (+$30)
- Orange G10 (+$30)
- Blue/Black (+$40)
- Black/Tan G10 (+$40)
- Black/Brown G10 (+$40)
Sheath Options
- Leather Pouch ($50)
- Leather Pouch + Firesteel loop ($60)
- Leather Pouch w/ foldover flap ($60)
- Leather Pouch w/ foldover flap + Firesteel loop ($70)
- Black leather (adds $10)
- Tooling (adds $10)
- Kydex - MOLLE/TekLok compatible ($40)
- Kydex Drop Loop - MOLLE/TekLok compatible ($60)
- Bright finish (+$0)
- Orange peel finish (+$20)
- Heat-colored finish - specify color range (+$30)
- Anodized finish (more even) - specify color range (+$40)
- Beadblasted (+$0)
- Stone tumbled (+$0)
- Other - specify
- Nail nick instead of Milled slot (+$20)
- No thumbgrooves (+$0)
- Striker tip - swedge, not a false edge (+$10)
