- May 17, 2018
I have been working on forging my first knife. Per nDog's request, I am posting my progress. It is based off the Yakut knife design. It only has an edge bevel (convex) on one side of the blade. The other side of the blade is flat and has a fuller in the middle. It has a stick tang. I planned on peening it but ended up using epoxy and pounding it onto the handle. Handle is a piece of walnut, I think.
Here it is after hardening.
The tang was too hard. It broke. I put a file to the rest of it and it seemed okay. I decided to just epoxy it instead of peening it as I originally planned.
Shaping the edge bevel.
The fuller
I cut the tang hole in the handle to be pretty tight. It is rectangular shaped tang. I also filed little "teeth" into the tang so the 2 ton epoxy would get in there and hold tight. It took a few good pounds to get it seated in the handle. I don't plan on being really rough with this knife. It will be mostly for carving and slicing. Not baton-ing firewood or anything like that. Here's hoping it holds together.
The epoxy has cured. Seems pretty solid. I'm going to leave the forging scale where it is.
She slept by my side that night.
Shaped the handle. When viewing it from the pommel it has an egg shape. The wood looks like walnut to me. It is definitely a hard wood. Correct me if you think it might be something else. I didn't use any stain. Just some Danish Oil (natural color). I still need to bring the edge bevel up closer to the spine and thin out the handle a bit. I will probably finish the handle with BLO after shaping it some more.
There's the fuller after some polishing on the blade. I am leaving the forging scale in the fuller.
I'm not as brave as nDog, so I'm not doing a bend test. I'll just test it out by using it and hope it never breaks. I will post more pictures when I finish her up and make a proper sheath.
The fuller
