- Jun 11, 2006
So with the new shop and the extra space I am strongly considering ditching my small forging press. It's been a good press and made a lot of Damascus but I out grew It many moons ago be did not have the space for the upgrade. So with that in mind I have started researching this future build. One thing my small press has taught me is speed might not be everything but it sure helps. My small press uses the harbour fright air over oil 20 ton jack and I honestly doubt it is actually 20 ton. But that being the case it seamed to move metal quite well at first but the big draw back is speed. It is slow so the dies suck the heat out quick and the press slows even more. So if I could keep the same tonnage as what I have but bump the speed up quite a bit I think it might be better then more tons and slow.
So would it be impractical to go with somthing like 15tons and shoot for as much speed as I can get. I would go with a single stage pump so I had a constant speed and no delay when the dies contact the hot steel. I would use at least a 5hp motor but not set on a RPM yet. What set me down this speed vs ton path was when I came across some posts by quick and dirty and his thoughts on forging presses. I was thinking more tons is better but his posts made me look at things differently and I can see how it could be better. My only issue on going for speed is getting into a situation where it's to fast to control accurately.
