- Feb 17, 2013
Hey folks, I found similar one but in better shape, is it WW2 too?
https://photos.app.goo.gl/f8zFW9cWKkN8jVZdA
Xfox, yours is a WW2 vintage 1219C2. Same vintage as hovercopter's - made after the change orders to curved guards AND thin (1/4") pinned pommels, but before the final change order to move the stamps to the guards.
Yours is in better shape than his, but obviously needs handle repair to be usable. Leather disk sets are available from Kabar. Under $10 the last time I ordered a couple of sets. You would need to clean up and reuse your pommel and acquire a pommel pin lone enough to go all the way through the pommel., since replacement pommels that available as repair items are all the modern style - thick (3/8") blind pinned pommels.
Determining if a KABAR brand 1219C2 or USN-MK2 is WW2 vintage or a post 1976 reproduction, KABAR has made it extremely easy to figure it out.
There are TWO paths to determining vintage.
The first, and to me, the easiest way is to look at the stamps and their locations. If the stamps are on the guard - WW2.
If they are on the ricasso, a narrow legged font that is shallow-stamped is WW2. Wide legged, deeply stamped marks indicate post-1976.
The second way is to look at the pommel.
If it is thin (1/4" thick) and the pin is visible from both sides, it is WW2 vintage.
If the pommel is thick AND pinned, it is post-1976*. NO WW2 1219C2 or USN-MK2 was ever made using a thick (3/8") pommel attached with a pin.
ALL WW2 era thick pommel 1219C2/USN-MK2 knives have PEENED pommels - the knife was constructed with the tang protruding slightly through the butt end of the pommel and then was peened tight.
*IF you encounter a thick pinned pommel 1219C2/USN-MK2 with either the thin shallow font OR a stamped guard, someone rehandled/repommeled it with a modern replacement parts kit from KABAR. I have an RCC guard stamped one that I rehandled like that somewhere. When I bought it, there was a blade, the guard and 3 really brittle, crumbling leather discs.
Kabar used thick, blind-pinned pommels AND a different font/size/depth for the USMC and USN stamps so that no one could "manufacture" WW2 knives out of the reproductions.
