Foxy Folly Review with Pictures
I picked this wonderful kukri up from DOTD 10/24. It arrived in just a few days from Yangdu. Upon opening the box and unsheathing the kukri I was in love.
Blade - For the who are unfamiliar with the Foxy Folly it has a very wide blade with two large fullers on each side. The blade is also quite a bit thinner then other kukris offered by HI its same size. The kukri has a very light feel to it, giving it a fighter type of feel to it, yet it still feels as though it has enough weight to do some light to medium chopping (maybe even hard, though I didn't try). The fullers on the blade are very well done, with only the occasional ripple due to forging or the grinding, they are very elegant and beautiful yet still have that man made look. The finish of the blade is also very well done, its like a mirror and without grind mark showing. The edge came with a great deal of convex to it that was very well done, but not that sharp. While the sharpness is sufficient enough to do work, its not as sharp as it soon will be ;).
Handle - The handle, like the blade, is very well done. The handle is shorter then on other kukris that share it's same over all length, but it is not uncompterble. The shape of the handle is fairly wide and thick, but it seems to fit just fine with the shorter handle. The wood on this one is chandan and is very beautiful, it has a wonderful glow of reds, oranges, yellows, browns, blacks and purples all rolled into one. The fittings are white metal, they are all very nicely done with the bolster and chape having clean solder lines. The butt cap fit very well one this handle. It came with no sharp edges or any protrusions on the handle.
Scabbard - The scabbard ranks up with one of the best I have seen from HI. The leather is top quality, it is smooth and without any rough spots. The fit of the blade inside of the scabbard is perfect. When inside of the scabbard the blade does not rattle or shift and the whole rig can be tipped upside down and even shook quite vigorously yet the blade remains. While the blade in the scabbard is very secure, it can still be easily removed with a little force. The chape fits the scabbard very well with only a little glue showing. The frog is also very well done, it fits the scabbard great and is made from thick leather. The frog does not seem to be cut quite even along the bottom, though it's nothing noticeable unless you are looking for it.
Chakma and Karda - Both the chakma and karda share the same level of finish that the kukri has. They are both little mirrors and without grind marks. The karda comes with a decent edge on it, better then most others I have seen. While the edge on the karda is a little toothy it is plenty sharp enough to do some cutting (no butter knife sharp here!). The handles on the chakma and karda are the same wood as used on the kukri. The wood on the tools is also very exquisite and share that wonderful glow of various colors.
Chopping - The Foxy Folly really did great at what chopping I did (what I would consider light - med). I tried it out against a few different types of wood, and in difference thickness. The Foxy Folly did great at chopping, and even made batoning a breeze. I found the chopping to be around the same level or just right below a 15in AK, however the batoning was much easier then an AK.It had a very nice balance to it, almost making it feel like all it wanted to do was work. The blade gave off a neat ring when it was polled out of the wood, and when it was going though the air the blade would make a whooshing / whistling sound (neat!).
Overall I would have to say that I just love this kukri. The FF has been on my want list for quite some time, and now that I have it, I am already lusting after another.
Thanks Yangdu.
Here are the stats of the kukri.
Blade - 12"
Handle - 5 1/8"
Overall Length - 17 1/8"
Blade Thickness - 9mm
Point of Balance - 3 1/2" away from bolster
Weight - 26 1/2 oz
Kami - Sher
You know, you have the FF I'm most curious about. I know the 28 ounce anf up version chops well. The 24 ounce version in my opinion did not and was a mistake. But your 26.5 ounce model I believe might save just enough weight over the 28 and heavier, be more packable, and yet still chop like crazy.
My intuition is telling me it may be the magic combo. Just my magical thinking, though.
munk
munk
You may be right Munk. The kuk does feel like magic. :)
i lurve me my foxy folly blades... one in chandan by bura (crescent moon), one in monkeypod wood by kesar (double flag)... as close to 17.5 inches as i care to mention.
personally, i would love to see a 30 ounce one, or perhaps heavier... i know some were made of cold, and i bet they are stout. i'm a freak though.
combining that chopping thread back yonder (crow vs bowie/etc), i have a 20 inch AK, and it's a thing of power. lurve it. a 22 inch GRS or so, would float my boat. a sgt khadka even more so - his lines rock.
bladite
Yangdu set the weight at 28 ounces after the 24's were such a problem.
I'd actually asked her for 26 and above, but she wisely and stubornly ignored me. She probably knew the Kamis would make the weight range anyway, and they have. Now, I know there's been at least one recent DOD heavier than 28and now we see a 26.5.
I thought there'd even been a post 30, but I'm not the detail man.
Anyway, keep waiting or write Yangdu and see.
munk
I wouldn't mind picking up one of the 21.5" FF that came in at 24oz. Of course they wouldn't be for chopping, but I bet they would handle great. The ones that where offered in 6/05/05 had such attributes, and the handles even looked like they had more curve and taper in the middle going inward towards the ring.
I have never seen or heard of a 30+ oz FF, but maybe Norm would know. As this one is 26.5 oz and it does work wonderfully. I wouldn't go any lower in weight, as it could severely hinder its chopping ability (and maybe even stability if it goes to light). I agree with you Munk that one in 24 oz would certainly be pushing it, though I suppose if it was just meant for martial use, like a kobra, then I am sure it would excel tremendously at such a task.
One thing that I forgot to mention in the review is how this kukri sounds like a tuning fork when you tap the edge. It sounds much like some of my harmonically balanced swords that I have owned. When one taps the kukri on something hard (or even a finger nail) you can hear a wonderful sounding *ting* right in the point of percussion. As you move towards the tip or the bolster the sound is dulled into more of a *tink*. I have not experienced anything like it on any of my knives nearly as clear as this one, I have only heard is as clear as on my higher end swords. It's very interesting.
---Please stop me if I sound crazy. :D
You're not crazy.
The FF is a bit of a mystery to us; in the end, they either chopped well in spite of their weight, or they didn't. I never could figure out what variable(s) decided this and thus, I can't tell the difference between them visually. The only way to know is to go out and do some chopping.
I've often said that the FF is my favorite in the 17-18", bar none. I still think so. In terms of sheer effectiveness vs. portability it's just a hair behind the Satori Special and my 15" villager BGRS -- but only just. It remains firmly in my top five.
Good review.
(And yes, mine rings also.)
You're not crazy.
I have one of the 23oz ones and you pretty much summed mine up. Effective and portable. Mine beats my 15" BGRS and is as good as my 17.
Someting about the weight distribution on mine is you swing it around it doesn't feel as HEAVY as my 17" 23 oz Ganga Ram. But it chops as well and machetes even better.
The handle on mine was a bit too fat, but I slimmed it down and it is probably my favorite HI. Doesn't seem to hurt the tendons in my arm as bad either.
I have a beautiful FF, but have not had an adequate chance to put it through its paces and get a real feel for it. I'll have to do that over Christmas break. Thanks for the inspiration! I have yet to get anything from this place that didn't really talk to me in some way. Some more than others, but you just have to discover the beauty in each piece.
Chris
Great review! And excellent pictures. You are doing some good write-ups. :thumbup: Several of us have commented in the past on the wonderful ringing sound you get from these. The new batches of chandan coming in the past few months with all these colors are stunning. All mine are the old dark purple, and I would dearly love to get one of these.
Munk has me at a disadvantage; I know of several now coming in at 26 oz. or so, but don't recall too many at 28 and too lazy to search. I'm sure there were one or two. IMO 28 oz., which was to be the new standard to go with a new slimmed handle (as announced by Yangdu in January I believe) is the way to go, but not having handled one I'm not sure but that 26 oz. might indeed be the best all round compromise. 24 ended up being a great fighting blade but too light and thin for chopping, and I know of at least 3 that have bent from that. Yangdu also carefully clarified this in a later post.
My favorite FF is the 1 of 2 Sher prototype that I snagged from Dan that came in at just these dimensions but at 34 oz. Yvsa has the other, and his is a couple oz. lighter which would be even better. But mine is a great chopper and sharp as hell, and very well balanced. A half pound heavier than this, and you would feel it, but it hits hard. I don't know of any others other than these two that are over 30 oz.
Anyway, I'm looking forward to getting one someday at this length right around 28 oz., which would work for me, with a lighter colored wood handle. (I do have a 29 oz. version but it is one of the other set of prototypes at almost 22" long.)
The only other change I would want is for the handles to come in slimmer as planned back in January, and to have a handle at least 5" long. Most of these are just slightly short for folks with larger hands.
Norm
I too would like to see a little slimmer handle. The current one is alright with me, but a little slimmer may feel better to more people.
As for the length of the handle, I really don't have a problem with it. I normally like longer handles, as I consider myself to have larger hands then normal, but with the current length it just feels right.
Maybe I am just odd. ;)
The Foxy Folly is my favorite all time khuk in the original length and weight with the 17" model tied for first place.;) :D :cool:
I was able to get rid of my large GRS when I got the large Foxy Folly and the 17" FF has taken over most of the duties of my BGRS.:thumbup:
I'm like Dave R with my FF being my favorite in the 17" - 18" range with my BGRS coming in a close second.
My Chitlangi made by Jag and Prem is my favorite longer and lighter khuk.
I'd have to give it some thought as to what makes up my top five as it would be hard choose but a khuk from another house would be among them with the HI 12" AK coming in at number five I suppose from right off the top of my head. Everyone needs a smaller knife to work with and the 12" AK makes an excellent rough out carving knife!:thumbup: :cool: :D
The one size I don't have! Always had a problem with the handles on these being too small, but maybe will try again. They are nice blades.
Norm
