Today I started working the stag. When I took this project, stag was a requirement. When I did the design, I didn't realize how big the slabs would need to be. It took quite a bit of back and forth with Culpeppers to get a workable size and then I had to wait two months for them to be dyed. I would have really preferred to use a taper but there were not any available in a size/shape that would work. These slabs are 5" x 1-3/8".
I've never worked with stag but, I have worked with Mammoth ivory on a few projects so I just approached it in the same way; work everything from the back. I started out using the liners to determine the best positioning. Once I was happy with how the stag fit and the way the grain laid on the knife, I marked the back of the slabs.
Untitled by
Bob, on Flickr
Next I need to thin the slabs. Thinning them evenly would not get the fit I wanted so I marked the ends and then ground down to my marks.
Untitled by
Bob, on Flickr
This is my weapon of choice for grinding the back sides of mammoth scales, it worked just as well on the stag. I put the slab down on the running disc and then control the material removal by putting downward pressure where I want the material to come off.
Untitled by
Bob, on Flickr
No blood on the disc. I actually manage to only burn my fingertips when the material gets hot, I'm very careful not to grind my fingers. The stag clogs the 80 grit paper pretty quickly; todays work took two sheets.
Untitled by
Bob, on Flickr
After several rounds of "check the fit then grind", I have the slabs thinned down overall and tapered to be thinner at the front. Not much margin for error here.
Untitled by
Bob, on Flickr
Untitled by
Bob, on Flickr
Here you can see the taper from front to back.
Untitled by
Bob, on Flickr
This is as far down as I'm planning to go at the front. If I thin any more, the valleys will drop below the guard fittings. I will bring everything else down to the guard.
Untitled by
Bob, on Flickr
Both slabs fit to the frame assembly. That is it for today.
Untitled by
Bob, on Flickr
Oh...except I also made this zirc thumbstud and insert today. I'm waiting on the right size washers to finish this one up. Should wrap it up tomorrow.
Untitled by
Bob, on Flickr
Bob
