Free hand edges are better than most edges made on these gadges,just get a cheap stone and practice.
Its easy to sharpen on stones,just practice,get norton sil carbide,india,or some of dmt stones,and with practice youll get better and ,sharper and more durable edges than on any of these gadgets,with stones you can sharpen to your own specific angle,create convex edges etc,its all matter of technique.Most gadgets do not produce optimal edge ,and youre stuck with n9t s9 sharp knife that shaves hair and cuts paper.Stones are for real world use ,although some gadgets are pretty good like sharpmaker,but in combination with stones are excellent.
However, the idea that free-handing produces "better, sharper and more durable edges" than a Wicked Edge or Edge Pro or many other good systems, is patent nonsense.
In my own use I don't really see any difference between the two in any way that matters for offhand/anecdotal standards, so I agree with this statement.
But...CATRA did find a couple degrees of convex (typical of good freehand standards) resulted in longer lasting edges during testing - they felt strongly enough about it to have developed a powered grinder that produces just such an edge.
On my own guided system I've tinkered around (unsuccessfully so far) with controlled ways to introduce some noise under the assumption it would speed up the process a bit, better hide warps and twists in the primary grind, and possibly improve burr removal. It would also induce that two degree variation that CATRA endorses.
Interesting. Do you have a link to that study. I'd love to read it.
Yes the gothic arch edge does have less material behind the edge than both concave and flat ground edge bevels.
The CATRASHARP model has this type of wheel as standard and is 32° at the edge and 30° at 1mm back from the edge.
The CATRA I 100 as standard is not a gothic arch wheel and so you get typically 32° at the edge and 33° at 1 mm back on a new pair of wheels, but as on this model the wheels can be recoated the wheel do get smaller and so can drop down to 26°/27°. We can however make special wheels for the I 100 with a gothic arch profile giving you 32° at the edge and 31° at 1mm back.
Q16 : What is the CATRA Gothic Arch edge system?
Normally when a knife or blade edge is sharpened by drawing the blade through interlocking abrasive sharpening wheels the edge bevel (or cannel in old Sheffield cutlery industry language) is slightly concave in shape following the curvature of the wheels themselves. However many knife experts believe it is better to have the bevel in a convex form, which gives an apparently sharper edge for the same tip angle. (Some experts also believe the edge is stronger, but we at CATRA don't subscribe to this point of view). CATRA's range of spiral interlocking wheel sharpeners can with our subtle engineering modifications sharpen all types of blades and knives with this convex (or GOTHIC ARCH shaped) edge, thereby giving that extra boost to an already very high level of sharpness.
I've been free hand sharpening since I was like nine years old. I'm fifty nine now.Who free hand sharpens and why / why not.
To put it another way, and this is the way I always put it in these threads, lets say NASA or some other out fit needs a precision part made. Tolerances to a fraction of a degree and to a few microns thickness.
