I bought one today from Lee Valley Tools in Canada. I walked into a store and bought one. They were advertised in the Christmas catalog. I bought a Frost's 3.5" Mora too. The Mora is awesome, but the Bivouac knife is pretty cool too. The factory edge is crap, but quite up to the task of eating steak. I'll take my DMT stone to it when I get home and see how it takes an edge. I doubt I'll waste my time going at it with my waterstone, it's not going to be doing anything but slicing anyway. The blade is marked "BIVOUAC" and in smaller letters beside it, "FRANCE" and "INOX" stacked above each other.
The sheath it comes with is cheap grey webbing with a velcro closure. Ugly but functional. On the back it has a bent heavy gauge wire doohickey that looks to be for attaching to a web belt of some sort, but there is also a loop for a normal belt, about 2-3" wide. Being a Canuck and unfamiliar with US issue webbing, I have no idea whether it's compatible.
The Lee Valley Tools catalog advertises it as a "liner lock", but it is a lockback. The lock release is a tab that sticks out the side of the knife, but it's stiff enough that it'll probably resist accidental activation. It seems fairly secure, but I don't plan on using this for anything but eating. I have no doubt that it will hold securely if you're eating anything softer than solid wood. The blade has a thumb notch for opening.
The can opener has a thumb stud for opening, but this appears to have been merely to conserve space. You have to remove the spoon/fork from the knife to get at it, and it is very stiff opening. It holds open with an even stiffer slip joint. It is still new, but I have to close it by pushing the back of the can opener against a hard surface. I'll try it on a can when I get home. The sharp edge faces out and looks pretty sharp. There's a corkscrew too, but not being a wine drinker, it'll probably be awhile until I try that out. The fork and spoon are plain but functional. The fork has a proper angle to the tines to make it feel like a real fork. The spoon has a flathead screwdriver and a hex socket built into the handle. Perhaps someone can tell me what they're meant to fit?
