1. Here is a new in sealed bag SureFire Millennium Light: This is what the web site says: Slightly bigger than the M951 system, the M961 uses the same XM tailcap with built-in constant on/off push button switch. It also has a pressure pad on a 7 inch wire.
Features: Batteries - Three SureFire lithium SF123 3.0 Volt with 10-year shelf life Lamp assembly/Runtime - SureFire MN10 xenon gas-filled lamp assembly with 125 lumens output for 60 minutes, and a spare MN11 (225 lumen) lamp assembly Mount - Thumbscrew. This is new in sealed bag with a new in sealed bag extra lamp (225 lumen) and a new in sealed bag "Loose Equipment for the Model 900A & AB Rail Mount System" This light was purchased for a M-4, but was never used. This light is bright and comes with all the extras. The mount is the thumb version, not the quik detach lever. $250
2. Next is a SureFire Z3 Combatlight with two extra lamps (1 P90 and 1 P91 lamp assy) both in sealed bags. This light is new but has been riding around in it's plastic Surefire Holster (this is included) in the bottom of my gear bag so the finish has some rub marks around the "no roll bezel". This light has 3 new batteries in it. $100
3. And a lightly used Black Wilderness Tactical 1 3/4" belt. This is the 5 stitch model with steel buckle in size 36. I went to the titanium buckle so this one isn't getting the use or getting into the rotation. $25
Pixs are on my For Trade section. I am open to trades! Will combine items from my other FT & FS threads for the right steel. I'm interested in heavy duty custom, semi custom production folders- drop point, spear point blades. Striders, Crusader Forge, Chris Reeve. Some Busses, Ferhmans, Striders. Hit me up and we'll sort out a deal. Look at my other for trades and see if there's any interest. If you don't like the item, after recept, then we'll reverse the deal- no blood no foul!
Let's keep this in the US. Thank you.
