I can cut paper just not slice it. I used about 50 strokes per stone on both sides. Ill try to do more. Its a small cheap buck pocket knife I'm practicing on.
Hi,
But what does "cut paper just not slice it" mean?
Slicing paper (sawing) is the easier than push cutting (slow chop, no sawing motion).
Can you slice paper after the first stone?
What kind of paper are we talking, cardboard, index cards, printer paper,.... the thicker it is the easier it is to cut ... push or slice
hold up paper with one hand, knife in other, start cutting on edge of paper ?
I'm not sure of the grit I know its an extra coarse, coarse, medium, and fine and then one for serrated.
Ok, so sharpeningsupplies says
- Extra-Coarse: Black Color, 80 Grit, Sharpens damaged edges and extremely dull blades.
- Coarse: Yellow Color, 120 Grit, Fast cutting, resharpens dull blades
- Medium: Green Color, 220 Grit, Refines edges after coarse grits
- Fine: Red Color, 320 Grit, Produces keen cutting edge
- Ultimate Finishing: Sky Blue Color, 1200 Grit, Made of 96% alumina ceramic, Provides surgical finish to final cutting edge
Do I need to buy the other two stones I stated?
I would say "no need" for now
maybe
after practice figuring out how to get sharp off the stones you have now
re-evaluate your wants
of give some other guys a chance to chime in with advice
Maybe if you want to actually try shaving your face frequently maybe then get the higher grit stones
or if you likes wood whittling ... things that commonly use higher grits
but it doesn't take high grits to get high sharpness and do tricks,
jigs like gatco help with that a lot
minimum-grit-or-micron-hair-splitting.1493089
does the edge have to be mirrored to be in the razor sharp category? Mirror polish not required...
