Gerber Dime Multi-Tool.
Here is my long-term review of the excellent Gerber Dime multi-tool. I said in other posts that I've carried this tool for around a year, but I recalled purchasing it prior to Nutnfancy doing his Youtube review on one. He posted his video in May of 2012; so that puts mine at around a year and a half old.
It wasn't a planned purchase. I didn't even know it existed until I saw it in the display case at the Brigade Quartermaster on Ft. Stewart. I liked the idea of having a small tool to carry on my keys, since the Gerber MP600 I was issued was too big and bulky to carry out of uniform. I purchased the tool for around $20. It has been on my keys ever since.
http://www.gerbergear.com/Tactical/Tools/Dime-Black_31-001134
The tool is 2.75in in length, weighs 2.2oz and has 10 functions. The example I have is black. The finish has held up pretty well on the tools themselves, but the aluminum scales have suffered quite a bit of wear from rubbing against keys in my pocket. It doesn't bother me though. In fact, I really like the look. I don’t know if its due to the finish or not, but I haven’t had any rust issues with this tool.
The main tool on the Dime is a set of spring loaded needle nose pliers. They come to a very keen point, and can easily be used as tweezers. There is also a wire cutter portion on the jaws. The pliers are very useful, and have been tested multiple times. I will warn that they are not heavy duty, and can be damaged by putting too much force on the tool. I have twisted mine once. I can’t remember what job I was doing, but I remember that I was asking a bit much of the tool. Lucky for me they went back to shape. The A symmetric handle shape is quite ergonomic. I use the convex side against my palm, and the bottle opener gives a little extra length. I can get 2 to 3 fingers on the concave side.
Easily the most used implement on the tool is the flat head driver. I use it as a driver, a pry bar and as a scraper. One down side to the flat head driver is its location on the hinge side of the tool. Because of this, it cannot be extended by half opening the tool as the Philips driver can.
The Philips driver is acceptable, but not great. It is two dimensional, short and includes a file. Surprisingly it works fairly well when employed as a screwdriver, but still cannot compete with a proper Philips. The file may work for fingernails, but I have used it to smooth burrs on metal and it’s cutting ability has pretty much gone away. It’s placement on the tool is nice, as it can be extended by opening half of the tool to reach deeper set screws.
The scissors are/were quite good. They have cut everything: paper, strings, zip ties, tape, small wires, 550 cord and more. The “Thumb Ramp” of sorts is about double the thickness of the jaws and keeps things comfortable when used. I didn't realize how much I used them until the spring broke a few weeks ago. Originally I thought the spring just wore out, but when cleaning I found a small crack near it’s base. I have contacted Gerber about this, and they told me to send it back for warranty repair.
The second most used tool is the knife blade. I carry a Waved Spyderco Endura 4 as my primary EDC knife. It is purely for emergency defensive work and I never cut anything with it. When I need a cutting edge, I use the Dime. I have never had anything to cut that the Gerber couldn't handle. The blade is a short, sheep’s foot style with a double bevel edge. It is made of 3Cr13 steel, but touches up nicely and holds enough edge to get me through my day.
A unique tool is the package opener. It has a finger choil area so you can choke up on the tool and keep it from folding during use. It makes quick work of clam shell packaging. It is very useful and I expect this implement will be showing up on more and more multi-tools as time goes on.
The bottle opener. What can I say? It works. I really like the fact that it doesn’t have to be opened to use; it’s always out. Running the key ring through it as I have slightly obscures it, but it still works. I do this because I accidentally broke the small ring the tool came with. Most all of the beer I drink requires an opener, so it has come in handy.
Oh, tweezers! Near the bottle opener is a tweezers stashed under the scale ala SAK. I can’t say much about them aside from they work. I use them quite often at work testing illegal substances. I haven’t ever used them to pick out a splinter because the pliers work good enough at that.
All implements aside from the pliers are accessible without unfolding the tool. Nothing on the tool locks, but the springs are secure without being too tight- Everything opens easy enough. I will be sending it back to Gerber for warranty repair on the scissors and I’ll replace it with a Leatherman Squirt PS4 while its away. After carrying that for a while, I’ll try and figure out which one I like best. Either way, this tool has more than paid me back for it’s price and I highly recommend it. If you need a small, light, tough little tool, the Dime might be right for you. Thanks for reading.
That's a nice look at the Dime. All I would add is that the wire cutter is not sharp, and can benefit from a few passes with a file. But its a nice tool, and a regular in my rotation. I do find that its also not quite as elegant in design and execution as the Leatherman PS4, and I prefer not to have that bottle opener sticking out there, but those are small quibbles. I like the Dime enough to buy each color, and I really like the way yours look after all of that usage. Good stuff.
I meant to add that the scissor spring also broke on Mrs. Powernoodle's PS4, and it will be going back to Leatherman (along with a Juice S2 that has a jacked up plier). Maybe the scissor spring on these tools is not its strong point. Again, very nice review. I've gone back to read it more than once, but I'm sorta weird in that regard.
Thanks, and I'll take note of the spring problem. I agree that the Leatherman is a bit more sleek and streamlined. I'm looking forward to putting one to work. As for the repair, I really hope Gerber will just replace the scissors and not the entire tool. I'd like to keep my beat up one. At least swap the scales over!
One thing that struck me about the dime is that it feels heavier than other keychain multitools. It's feels hefty despite it being physically smaller than some other brand offerings. I don't know if that makes sense.
I like it.
Just bought the Gryll's mini-tool this weekend. The pliers were/are great, but otherwise, it's clearly not in the same league as this Dime.
I definitely want to see this A/B with the Squirt, for sure. One or the other is on my short list. Sticking with the Leatherman would have me with the trilogy of sizes, LOL.
You have to request that they repair and not replace it. I only live a few hours from Gerber and had a multi tool that I managed to break off a couple of the tools. I mentioned that it had sentimental value to me as it was a xmas present from my dad and I had carried it during my time in the Army. She said to make sure and put in writing that I want it repaired and not replaced. They mailed it back to me within 2 weeks repaired and they included my original wore out nylon pouch along with a brand new pouch. Great customer service!
Will do. I thoroughly explained it in the original message I sent Gerber on their website, but I got an automated response back. The email said to send a detailed request/explanation of the problem when I send the tool in. Its good to know they will work with customers on things like that, though.
The particular model I brought to them was no longer in production either so one of the tools that was snapped off they had to replace with a black coated tool that has a black coating on it and looks like they had to make it fit but it functions properly and I didn't care I was just happy to get the same tool back. :)
Got my side-by-side last night. Verdict for me will be with the DIM. Slightly longer, and heavier than the Squirt. About par with the Micra. To my eye, the Dime appears to have the superior pliers, with the front portion able to close tightly against one another. Also, the amount of tool in your hand to exert leverage. The scissors are superior in feel/operation, and appear to open wider than the LM. (Neither pair is anywhere near a SAK/Micra)Bottle opener is quite unique, of course, and heck-for-stout. Tweezers are nearly a dupe of what comes in a SAK. The blade is likely a wash between the two, but I like the belly of the Dime's better. The LM's is essentially the same blade as inside a Micra.
Those are what stood out for me, though YMMV.
