Fudo,
Thanks for asking, and as a relative knife "newcomer" I hope I can help answer your question.
On fixed blade knives, not counting those "Made from one piece of steel" knives like Chris Reeve knives, most blades are made from a single piece of steel that is either ground down (the stock removal method), or forged and hammered, then ground to finish (the heat and beat method).
Either of these methods, regardless of blade grind or tang taper, still (generally) have the handle material and hilt added as seperate items.
The tang is the steel part of the knife that is in your hand, regardless of any material that may cover it.
Some knives have a reduced tang, (shorter than full knife length), or a tang that is soldered on after the blade is made. There is a school of thought that these types of knives are not as strong as a knife in which the blade and tang are one piece of steel, tip to tail.
The integral, whether stock removed or forged, has the blade, hilt, and tang (sometimes the pommel too) made from one piece of steel, and is turned down, (relieved, material removed) to fit the handle material.
In theory, this is the second stongest knife configuration available, (second to the one piece designs), but is most desireable due to the inherent strength and customization available due to various handle materials and configurations available.
Robert Loveless was one of the first "Major players" to use this expensive, time consuming method, which has been furthered by his protege Steve Johnson, and now by Steve's Protege Ricaro Velarde.
When you hold your first clean, "slick" integral, the light is gonna go "pow" in your head, just like the old flashbulbs did in the movies.
It's an epiphany of sorts...the usual response is "WOW"
Are they going to have any real "value" over time? Probably not. I mean look at the 3 configurations of Randall Made Knives mini's for example. They were limited to 1000 on the first model, and 1500 on the next two...
The 1st ones, the mini #25's listed for $260 5 years ago, and now sell for $900-$1000 per. The mini #1's listed for $280 3 years ago, and now sell for $650-$800. The newest, the mini #3's, still being delivered, originally listed at $310, are selling for between $550 and $700.
Is this a good investment on your money? Probably not, being that the NASDAQ is doing so good... What, the NASDAQ is blowing chunks? Oh, ok, I retract my former statement and give the new Gerber/Loveless Integrals a firm qualified "maybe"
I for one have earmarked a few...(Thanks A.G.!)
It's your call there dude, but if statistical trend analysis means anything to ya, ya just want to give the G/L integrals a serious thought...
(Then again, ya may not...)
